Exhaust Sound
Old Apr 1, 2011 | 05:02 PM
holycrap300's Avatar
Exhaust Sound
I've installed my kamikaze headers & downpipe today.
My problem is that when i get over 3k rpm, it sound like civic... lol. Like if i had an vtec at 3k.
But lower than 3k, the sound is loud and awesome, so if i get a resonator + new high flow cat + Dynomax VT.
Would it help getting louder?
Resonator = Test pipe? Or im wrong
Old Apr 1, 2011 | 08:05 PM
mci2727's Avatar
The sound you're hearing over 3k is very common on our cars.
I had it and here is my two cents;
I found that the flange gasket was not sealing tight enough and needed to be replaced with a thinker one.
I could clearly see carbon streaking on the old gasket once off.
I would assume this is your "civic" sound as well.
It is just enough that it creates a exhaust leak when under high load.
Old Apr 1, 2011 | 08:30 PM
slatermvp's Avatar
mci - question do you have the part number for the exhaust gasket or could using two gaskets work as well or no??
Old Apr 1, 2011 | 08:56 PM
steven121's Avatar
get a resonator it should lower the sound, but thats because your N/A the sound travels through hollow pipes, with a turbo it reduces the noises while creating power. If you get a resonator with your setupit will make your idle alot quieter as well as upper rpms. It also depends on the muffler you have as well I had a magnaflow which was stuffed very well reducing noise as well as not robbing the power.
so your choices is new muffler or resonator as your cat/test pipe
Old Apr 2, 2011 | 09:01 AM
mci2727's Avatar
I don't remember it.
I just took my old one to a parts store and matched it up to a FelPro.
Old Apr 2, 2011 | 09:30 AM
02-Lancer-Es's Avatar
On my old setup I had the header , test pipe with stock exhaust . It actually felt faster than with a greddy exhaust and magnaflow .
Old Apr 2, 2011 | 01:21 PM
which gasket you talk about? Header to head, header to downpipe or downpipe to the cat?
I've got the Ractive fireball muffler + Racing cat ( What was wrote on the box.. lol ) it mean high flow?
Someone told me that might be the downpipe was making this sound
Old Apr 2, 2011 | 01:30 PM
because its been installed yesturday, i dont think it come from a leak...
I was thinking about the Dynomax VT 2¼ inch.
Old Apr 3, 2011 | 12:57 PM
mci2727's Avatar
I'm talking about anyone of your 2 hole flange gaskets.
They are notorious for leaking if they are not thick.
Could be wrong but if what you are hearing is a fast popping sound at high rpms then that's what it is.
Old Apr 3, 2011 | 01:02 PM
4G63kevin's Avatar
The header is what gives you that "ghey" civic sound. I'm assuming it's an equal length header?
Old Apr 3, 2011 | 07:57 PM
Ya its 2.5 header and downpipe size, and my catback is 2¼...
Old Apr 3, 2011 | 08:10 PM
Raikiri's Avatar
try getting a highflow cat installed on your setup. if helped with the sound when i put in headers/downpipe on my car when it sounded like a jetengine at idle
Old May 11, 2011 | 08:11 AM
Well i changed the muffler recently, it sound lot quieter.
What i exactly got is : Kamikaze header (2½) + downpipe³(2½) + Racing Cat(2½) + Custom 2¼ catback and a dynomax muffler VT.
The sound doesnt sound bad on idle and rev it, but when i put gear and move, it sound acute in a certain rpm range and Throttlebody full open it sound worse.
-Adding resonator would only make less noise and add more resist? right?
-Using stock downpipe would change something? About the sound and power?
-Ill try to get high flow cat from magnaflow and see..
THNX ALOT for you help! im despair lol
Icegod87
Apr 26, 2016 08:31 PM
kingjhay723
Jul 19, 2014 07:39 AM
Tekniq
Jun 6, 2012 04:04 PM
BoOsTinGEVO190
Apr 10, 2012 09:24 PM
Turbo_M5
Lancer Engine Tech
Feb 28, 2012 05:47 PM
