Camshft Position Sensor
Old Jun 8, 2005 | 09:32 AM
JDog's Avatar
If anyone has complete repair instructions, that would be great. I'm more than comfortable doing the repair, but I'd like to have proper directions.
Old Jun 8, 2005 | 10:25 AM
HobieKopek's Avatar
It's seriously 1 or 2 bolts and a wire clip.
Old Jun 10, 2005 | 07:01 AM
JDog's Avatar
Where is a good place to get the part (Advance Auto Parts doesn't have it; they recommended the dealer)
Old Jun 12, 2005 | 12:58 PM
KillahB's Avatar
Originally Posted by Gemini_Lancer
Thanks AirQuez....more ?'s though,
Do I just call up the dealer and order the part from the Service Dept? Will they even sell it to me?
Could you give me a detailed description of the process of taking out the old and putting in the new sensor?
Thanks, I appreciate it greatly
Yeah, you can always order the part through the stealership. They should sell it to you outright.
For the Mirage, it was just one bolt... unsure of the Lancer.
Originally Posted by JDog
I've started having the same problem - sporadic check engine light, code reads as P0340, camshaft position sensor malfunction. Very similar mileage as Gemini Lancer - 43,000.
Two questions:
Is driving with this problem until I can get it fixed likely to cause any further damage?
What exactly is involved in replacing the part?
Any advice would be greatly appreciated. Thanks!
I dont know if it was because of the problem, or jsut hell in a handbasket all at once, but when mine took a dump on me, I ended up with a bad MAS sensor, and my timing was all over the place and the car actually started running on only 2 cylinders sporadically. That, and it finally died at the side of the street one day.
This is probably a stealership-only item. I have a working one at home, brand new, that I thought was the problem with my car when it wouldnt start so I opened it, installed it and took it out about 35 seconds later. If we can cross-reference the part numbers and they are the same, I can sell you mine for cheap.
Old Jun 13, 2005 | 04:07 PM
HobieKopek's Avatar
It's the same. I have one in my garage too.
EDIT: I take that back. It may be different after all. It's about $50 from mitsubishiparts.com though. Oddly the Mirage one is cheaper (which is why I say they may be different).
Old Jun 16, 2005 | 07:49 PM
KillahB's Avatar
Does it list the part number on mitsubishi parts?
EDIT: It doesnt but the Mirage part is like $55 bucks.... Damn I need CAPS.
Old Jun 16, 2005 | 08:27 PM
wthoevo8's Avatar
I think you should go to Autozone or pepboys, they can help you pull the code and clear it for free, if it don't come back, I wouldn't worry about it. Especially if your car is running fine. My evo throws those 335 and 340 codes once in awhile. Hope this can save you some $$$.
Stinkhammer
Aug 11, 2013 07:40 AM
leo_99
Feb 25, 2013 08:20 AM
Decepticon1225
Lancer Engine Tech
Jul 29, 2012 01:58 AM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
17
Oct 12, 2007 07:43 PM
8urv8
Jun 6, 2005 07:28 AM
