My Lancer truths
Old Nov 3, 2006 | 06:13 AM
  #91
SnapDragun's Avatar
Originally Posted by Blacksheepdj
What he said - the stiffness. Basically, it's how fast the shock moves after a bump. The stiffer the setting, the shock moves very quickly to get you back to traction. The softer, the shock moves slower allowing the spring to bounce you a bit (comfier ride).
Change the setting - knob on top. Turn one way to stiffen, one way to soften. It clicks to tell you where you are.
This guy knows his sh**
Old Nov 3, 2006 | 06:14 AM
  #92
SnapDragun's Avatar
Originally Posted by Danno
^ I never went with a header, after I saw the 1" pinch on the DP I figured whats the point, and I never got around to changing that out.
and this guy knows his sh**
Old Mar 9, 2007 | 10:47 AM
  #93
Blacksheepdj's Avatar
Updated with CF section...
Old Aug 26, 2007 | 03:40 PM
  #94
sgand's Avatar
Lots of great info here, sheep. Thanks for taking the time to write it up. However, I do disagree with your CF speech. Maybe it's just that I haven't seen anyone around my area with some, but I feel that having a few pieces wrapped in CF looks nice, not rice.
Old Aug 26, 2007 | 05:36 PM
  #95
ambystom01's Avatar
I think he's saying it's rice because you're adding weight to a car using a product designed for weight savings.
Old Aug 27, 2007 | 12:12 PM
  #96
Lil red '03's Avatar
Thanks for the laugh sheep. That was fun. Sad part is, you're right on the money with a lot of those points.
I don't know about the whole spring debate. I've had tein's on my car for about two years and they haven't given me any problems. However - having said that.... i run local auto-x events and as soon as i get home from the desert, i'm ordering a set of Megan coil-overs and a set of Falkens. I'm looking forward to a better handling car that can be more competitive on a regular basis.
I understand about the exhaust size debate too, and i've done some searching as well - but i just don't think a pipe difference of 1/4 inch will be that noticeable. That's my .02 but maybe you've seen different sites then i have.
Wax on.....
Old Aug 27, 2007 | 12:17 PM
  #97
ambystom01's Avatar
Well something to consider is that a 1/4 inch change in the diameter has a large change in the area of the pipe.
Old Aug 27, 2007 | 08:56 PM
  #98
You can disagree. But I'm still right...
Bottom line is that CF's purpose is in that it's lightweight. That's why it makes a good replacement part. When it's wrapped around another part, it's extra weight.
Super bottom line: (fake numbers)
Stock part = 10 lbs.
CF part = 5 lbs.
Stock part wrapped in CF = 13 lbs.
Now how the f**k does that make sense? You've gained weight and made your car slower. It's like trying to lose weight by eating cake...
Wax on.....
Springs are a mixed concept for me. I know that the guy that bought my struts claimed they were blown (yeah, it's been long enough that I don't feel too bad talking about it). I had upgraded to coilovers, so I didn't even use them after running on the Teins. But then lots of guys go for a long time and are fine. Maybe I should update it with my questions...
It's not so much going to different sites. It's that I changed a lot of exhaust parts. 2.5 inch just seems to be too much. But it's all going to depend on personal preference and modifications.
Old Aug 27, 2007 | 10:13 PM
  #99
pkcyrus's Avatar
Wheels/Tires
- Good tires are the single best handling mod you can make to your car. So stop buying strut braces. Get good tires first. ESPECIALLY on the Lancer, which comes with crap tires from the factory.
This is so very true. I don't remember if you had an ES or an OZ, but this is especially true for the ES (02-06 generation). Just about the only thing the y376 was good for was plowing through standing water from my experience, especially with it's excessively weak sidewalls.
zztt
Apr 23, 2014 06:31 AM
naucrx
29
Sep 7, 2009 08:18 AM
chrismnj
75
Feb 5, 2008 06:55 PM
i_love_spool
Canadian Forum
29
Apr 19, 2004 03:53 PM
