Amby's dyno day
Old Jul 20, 2007 | 10:07 PM
  #196
ambystom01's Avatar
It's not bored to within an inch of it's life.
Old Jul 21, 2007 | 12:30 AM
  #197
CamShaft's Avatar
Originally Posted by lazypiss04
Personally, I think there is something wrong with his car or it needs a tune. No offense, Amby. I only say this because I've felt changes in my car after every single install, mid-range, top end and a loss of low end torque (results from my A$$ dyno). In addition after driving a perfectly good running stock Lancer, my girlfriends, or even a friends Lancer with high comp pistons, I can tell a difference in my car and thiers.
When is the last time you changed your fuel filter. Maybe go for a high flow filter??? More gas, less draggin your a*s
Old Jul 21, 2007 | 09:43 AM
  #198
Green_Bandit's Avatar
So lets say for instance the 4G94s were some what "ported" from the factory, would they be on the same level as the 4G93 (more potent wise) and not just a 4G93 with a little more displacement? Or is there something I'm missing?
Old Jul 21, 2007 | 11:41 AM
  #199
ambystom01's Avatar
If you checked the graph you'd see lack of fuel isn't a problem, if anything I was running too rich. However when you compared my graph to the other lancer's graph they were nearly identical inidicating nothing was wrong with my car.
Old Jul 21, 2007 | 11:47 AM
  #200
ambystom01's Avatar
I don't understand your question, the 4G94 is already a bored 4G93, if you bored it anymore you'd have a completely useless motor.
Old Jul 23, 2007 | 11:36 AM
  #201
Originally Posted by rhyzin
the throttlebody sizes are different. 4g93 = 51-52mm, 4g94 = 54-55mm. a 4g93 IM can be bored to 60mm, a 4g94 IM, about 57-58mm, making the upgrade to a 60mm throttlebody kinda retarded on a 4g94 IM. what supporting evidence that a 4g93 IM is better, using the same size throttle body between the two, is the fact that the 4G94 IM reads more vacuum at WOT than the 4G93. you can make a hypothesis that the 4G93 IM provides more airflow. a bit more supporting evidence is that i had road dyno'd before and after the 4g93 IM install and had recorded a gain in hp. i wouldn't say the numbers were too important but that there actually is a gain and that it were in spots in the rpm band that needed it. as for a before and after on a rolling road dynamometer(dynojet, mustang), no dice as far as i've seen.
the next difference is the block assembly. due mostly to the longer stroke, the 4G94 packs an extra .2 liters of displacement and a natural increase in torque(inherent in a longer stroke). the diameter of the pistons only increased by .5mm, i think. what happened is the rev limit was traded in for more torque. the 4g93 has a higher rev limit. i don't know what it is off the top of my head, but the lancer revs to 6250 before fuel cut.
a minor difference is the valve tappets. the 4g94 has hydraulic ones, and the 4g93 has mechanical ones that need to be adjusted. that's just a matter of convenience. otherwise, you can swap heads.
everything else is mostly the same concerning the block. minor differences here and there but nothing performance minded.
the trannys are in the same family. that includes the RA and the 4G64. nobody i've heard here has frankensteined different gears like the honda guys. i'd love for a RA final drive.
the 02-03 clutch slave cylinder/bearing single assembly was reverted back to the mirage multi-part assembly in 04+. i don't know if you can run the multi-part assembly on the 02-03. if you plan to have the car a long time or go through trannies cuz of retarded driving, i'd look into it cuz it'll save a few buck on changing them out. no performance difference.
like Rock said, there's a difference in the fuel rails with the 04+. its returnless fuel system had mitsu redesign the IM for that year.
the MAS are different. there is a difference in plug connectors, but the actual opening isn't much different. not swappable, but they do have their respective swaps from other mitsus.
i haven't been here in awhile so i thought i'd post
I found it! For the most part its just the IM I take it...
Old Jul 23, 2007 | 11:41 AM
  #202
ambystom01's Avatar
The motor itself is different (bore and stroke namely, head is slightly different too).
Old Jul 23, 2007 | 03:27 PM
  #203
mtags24's Avatar
Glad to see you went turbo awd! I'm thinking about doing the same thing in a year or two, maybe a pat myself on the back for finishing school.
I really wish everyone would stop telling him there was something wrong with his car. There is no reason to believe amby's dyno results are flawed. Blacksheepdj had similar results, and they are both extremely respectable members of this board who know their stuff. If this was some guy with 15 posts saying his dyno shortchanged him, I may tell him to get a tune up, but not these guys.
Old Jul 23, 2007 | 03:34 PM
  #204
Blacksheepdj's Avatar
I agree 100%.
Seriously, though, mtags has it about right. This is a proven statistic that we've seen repeatedly over the years. It's not like this is a random blip that we can say "oh, it was just a bad dyno run." Nick's numbers were totally in line with all the Lancer knowledge we already have.
It's just a damn shame he's gone to the Subaru Dark Side. Hopefully he learns better and comes back like I did.
Old Jul 23, 2007 | 05:28 PM
  #205
ambystom01's Avatar
Hahaha I wanted to stay Mitsubishi but they have nothing that compares to a WRX. Some people suggested I wait for the evo X or the new ralliart but the evo would be way out of my price range and there's too much speculation about the ralliart for me to consider waiting.
Old Jul 23, 2007 | 06:30 PM
  #206
I know what you mean. I just know that I learned to hate Subaru after 2 years of ownership. I wish you better luck.
Old Jul 23, 2007 | 10:12 PM
  #207
bene's Avatar
congrats amby, now u can actually go fast
the upgrade feels nice
Old Jul 24, 2007 | 01:30 AM
  #208
njsdca's Avatar
its sad to see all the lancer denial, its like when i started smoking cigarettes and always said "no i'm not addicted."
hey though, i got to give it up props wise... and not to be a dick but better you than me haha, time for Audi S4.
Old Jul 24, 2007 | 02:21 AM
  #209
kungfugirl's Avatar
Originally Posted by Boeturbolancer
Remember guys a mustang dyno works under a load of up to 40% and is mainly used for tuning purposes since it simulates road conditions better.
On a dynojet you'll see a much better number as it reads under a no load condition. My mustang... when it was running... pulled 305whp on the dynojet but on the mustang dyno where it was tuned it pulled 242whp. Big difference and it sure felt a lot better than that.
I encourage you to hit up a dynojet to be sure of your numbers instead of the mustang dyno. I've actually seen stock evo's pull around 190-200whp on mustang style dyno's... we all know that they put down more than that stock!
It's a dyno thing... come on guys don't bash him for that... he's in canada and only has the mustang close buy. He should be right on the money for that kit. Also consider that my stock lancer pulled 63whp on the mustang dyno... then they told me to dyno on a dynojet since my car didn't really make enough power for the mustang dyno to read accurately.
taken from another dyno dispute thread.
Old Jul 24, 2007 | 06:58 AM
  #210
WADADLIG_OZ's Avatar
Please don't bring that dyno debate in here.
My car was dyno'd on a 2 different Mustang dyno's in 2 different parts of Florida and both times it pulled in the 125hp range. I know I posted both graphs somewhere around the board.
Thanks
WADAD
