Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
4G93 intake manifold installed
Old Jun 16, 2005 | 12:40 PM
  #181
Z_Lancer_Man's Avatar
Originally Posted by livelyjay
We've been over this before. Rhyzin has been trying to get this to work for a while now and I think he gave up. The DSM TB has something different with it for throttle position sensor I think (run a search through this thread for "TB"). Maybe you could get a Mirage TB for cheap and have it bored out and a custom butterfly valve made for the new bore. Might end up being cheaper than RRM TB.
EDIT: I was wrong, look up a few posts and you'll see Rhyzin couldn't get his apart or something. Supa Tek seems to be trying, but he hasn't posted in a while.
I read the whole thread and I'm still unsure. It sounds like it can be done with some minor wiring. But then again, if rhyzin can't get it, maybe I shouldn't even try.
Old Jun 16, 2005 | 12:44 PM
  #182
livelyjay's Avatar
Well, I think he couldn't get it because some bolts or screws were frozen on his. I think he was trying to swap TPS between the two and just couldn't get them off. But I am just guessing and I'd rather not re-read this whole thread again.
Old Jun 21, 2005 | 12:03 PM
  #183
Jotun's Avatar
Ok one more thing about the 93 Manifold before you buy it make sure it has the vacum fittings on it for the Brake booster and the sensor that connects right before the TB on the fron side of the engine. I am learning the hard way the really hard way.!!!
Old Jun 21, 2005 | 03:04 PM
  #184
livelyjay's Avatar
Mine is the same way. I think the 4G93 manifold off of the 1997 Mirage is missing the vacuum barb for that sensor. The reason is the throttle body has three vac lines going into it instead of two like the 4G94 does. You can see how there is a bump, but it's blocked off in the picture below. Does anyone have an idea of where to tap into vacuum for the sensor? Drilling, tapping, and putting a barb into that location is an option, just not an easy one since I don't have a drill or tap set.
Old Jun 21, 2005 | 04:06 PM
  #185
Alchemist's Avatar
you can drill a hole and JBWeld a barb onto it I know that stuff is tough enough to patch holes in exhausts
Old Jun 21, 2005 | 04:55 PM
  #186
livelyjay's Avatar
Jotun actually spliced the sensor vac hose into the PCV vac hose and says it is working just fine. Looks like things will work out easily thankfully/hopefully.
Old Jun 21, 2005 | 07:24 PM
  #187
KillahB's Avatar
To answer your question, I would not worry about it. You are correct that the 1997 4G93 does not have that little barb there. I dont have it on mine and it was never a problem. I'll PM you a pic of my setup.
How many vacuum sensors do you all have (Lancers) going up to the TB (from the area that is right adjacent to the IM itself)???
Old Jun 21, 2005 | 08:06 PM
  #188
Jotun's Avatar
Thumbs up
We have one sensor that goes to where Livelyjay circled in red which honestly I have no clue what it is also the power broke booster outlet is on the opposite side of the manifold. ike Jason said I just spliced the hose on the left front side of the manifold and put a vaccum T with a line going to the extra sensor and it got rid of my CEL so so far so good I just need to get a barb for the backside mine didnt have one so my power brakes are gone.... Which is very very very very scary especially when you have all of this new power at your foot and you want to puch it so hard..... Besides that I definately noticed a really angry growl from the intake campared to the hum it used to have all in all if you have a complete intake like Jason does its an easy install and very generous gains for the price plus it alwos you to maximize on other mods....
Old Jul 24, 2005 | 08:01 PM
  #189
dmgj3's Avatar
almost on topic...
ok, I have an 02 oz and just found out someone locally is sellin their aftermarket turbo off their 97 mirage...how well do you think it will line up? and I might even find a tb and put that in while Im at it. Thanks
Old Jul 24, 2005 | 10:24 PM
  #190
lookslikeanevo's Avatar
^wrong thread, and search please
Old Oct 10, 2005 | 07:42 AM
  #191
KillahB's Avatar
Bump up top for someone who SHOULD be doing this soon.
Old Oct 12, 2005 | 06:32 PM
  #192
WADADLIG_OZ's Avatar
Did all of the cruise control and other issues get resolved?
WADAD
Old Oct 24, 2005 | 05:00 PM
  #193
Trying to get a bite on another question.
When you guys ported the manifold how far in the runners did you get or did you just gasket match the ports? It's hard to tell from the photos how far in you were able to get.
WADAD
Old Oct 24, 2005 | 06:46 PM
  #194
generally you port for just about 1.5" or 1-2"
Old Oct 24, 2005 | 07:07 PM
  #195
rhyzin's Avatar
however long it takes to get a smooth transition from the ports from the flange to the stock size of the runner. it'd probably be around 1.5-2" like Z_L_M said but since the thing is cast, it might be different for each runner.
