Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
4G93 intake manifold installed
Old May 25, 2005 | 10:39 AM
  #166
Blacksheepdj's Avatar
Originally Posted by livelyjay
To clear up some confusion, and to help me out as well, can one of you guys write up a formalized how-to, with shopping list and tools needed, for the 4G93 swap along with the DSM throttle body swap (actually two seperate how-tos might be better). I think it would help everyone out a lot and clear up confusion since this post has gotten pretty large.
That would be nice. I'd gladly move it to How To and sticky it.
Old May 30, 2005 | 04:09 PM
  #167
Supa tek's Avatar
I have converted!! The sound is amazingly different. The intake sound from my cai sounds alot more potent. I also made my coolant lines run into one another to keep the tb cool. I havent gone a long distance with it but everytime I do go somewhere I cant but help to floor the pedal. A+ upgrade for the price. Also, if you run your coolant lines into one another just make sure before winter you switch them back to running into the tb.
Old May 30, 2005 | 04:22 PM
  #168
WADADLIG_OZ's Avatar
did you use your stock tb?
WADAD
Old May 30, 2005 | 04:50 PM
  #169
GreenPsycho's Avatar
glad to hear it man! its nice to see other people going for the g93 manifold
Old May 30, 2005 | 05:08 PM
  #170
Supa tek's Avatar
Yes, I did use use the stock tb but I am in the process of trying to put in the 1g 60mm tb. Hopefully I will have everything figured out soon with the help of airquez.
Old May 30, 2005 | 06:08 PM
  #171
rhyzin's Avatar
you guys will have a good chance if you can get the whole AIC housing off and switching them. i couldn't get mine off so i pretty much gave up.
Old May 30, 2005 | 08:30 PM
  #172
Supa tek's Avatar
Alls you need is a torque screw driver and the screws come out easy.
Old Jun 15, 2005 | 11:23 PM
  #173
Z_Lancer_Man's Avatar
Anyone know what the size of the plenum opening on the stock g94 IM is?
Old Jun 15, 2005 | 11:28 PM
  #174
rhyzin's Avatar
55mm
Old Jun 16, 2005 | 12:04 AM
  #175
Alchemist's Avatar
and the G93 is 52mm IIRC.... It's too late for me to go out and measure right now
Old Jun 16, 2005 | 07:14 AM
  #176
What would you think is the most you could safely bore it and would it be possible to fit a 1g or 2g TB to it? I'm trying to check other options for TB other than a bored stock one.
Old Jun 16, 2005 | 09:39 AM
  #177
Alchemist's Avatar
about 60mm on each. I won't go anymore than that
Old Jun 16, 2005 | 10:10 AM
  #178
livelyjay's Avatar
Ordered mine today. 1997 1.8L intake manifold, $55 shipped to my door. So the only things I need to hook this up are:
1) Two additional short bolts (match to the shorties already on the TB)
2) Custom bracket for throttle cable
3) Vacuum hose
4) Paint (optional)
Am I missing anything?
EDIT: Just FYI, I'm going to stop by the local dyno shop and set up an appointment with Stage 1 setup with stock IM. Then I'm getting test pipe (tried to get cat off yesterday, rusted in place) and custom mid-pipe installed and I'll put in the bored IM and bored fuel rail. Then I'll get dynoed again and see what happens.
Old Jun 16, 2005 | 11:44 AM
  #179
DriftRunSir's Avatar
where did you order your g93 mani from?
Old Jun 16, 2005 | 12:02 PM
  #180
livelyjay's Avatar
We've been over this before. Rhyzin has been trying to get this to work for a while now and I think he gave up. The DSM TB has something different with it for throttle position sensor I think (run a search through this thread for "TB"). Maybe you could get a Mirage TB for cheap and have it bored out and a custom butterfly valve made for the new bore. Might end up being cheaper than RRM TB.
EDIT: I was wrong, look up a few posts and you'll see Rhyzin couldn't get his apart or something. Supa Tek seems to be trying, but he hasn't posted in a while.
www.car-part.com
I ran a search for each Mirage year compatible (for some reason the "interchange" seems to think they are not all compatible), emailed the places that had the lowest price or no price and asked for quoted shipped to my door. Easy.
