Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
4G93 intake manifold installed
Old Mar 4, 2005 | 07:11 AM
  #106
2002lancer-OZ's Avatar
Hey, would there be any benifit from just swapping the manifolds without porting it out?
Old Mar 4, 2005 | 08:35 AM
  #107
bahamut's Avatar
Correction: I had to edit the 2g TB as 52mm, not 55mm as thought . . . makes no sense that Mitsu would do it that way.
Rhyzin: what year TB did you have?
Old Mar 4, 2005 | 10:04 AM
  #108
blaze_125's Avatar
Originally Posted by rhyzin
oh, if anyone is thinking of doing this, make sure you get an intake manifold from the mirages that have the engine facing the same way ours do.
By facing the right way do you mean: With the trottle body on the driver's side or do you mean something else.
Old Mar 4, 2005 | 10:59 AM
  #109
erockOZ's Avatar
From: Northwest Chicago Subs - Serving in Korea till 09
^ i'm pretty sure thats what was ment by the "right way". I think g4 and down mirages had the tb on the passenger side.
Old Mar 4, 2005 | 11:36 AM
  #110
blaze_125's Avatar
If that's the case, then it's only a matter of routing the intake pipe differently and figuring a way to properly hook up the TB cable
Old Mar 4, 2005 | 11:53 AM
  #111
WADADLIG_OZ's Avatar
Why go through all that.
That's just giving youself unnecessary labor.
WADAD
Old Mar 4, 2005 | 11:55 AM
  #112
rhyzin's Avatar
^yup. thats what i mean by facing the right way. 5G mirages tb are on the driver side where 4G and down are on the passenger side. as far as rerouting the throttle cable for the 4G manifold, i think our cables are too long. it would look nasty in the engine bay with all this extra wire about. the cable is hard to bend around anyways since it's a metal cable.
bahamut: i have the '92 NA 4g63 throttlebody. i also have a broken turbo throttlebody around and the 2 are identical except for the throttle body entrance and the NA one doesn't have the vacuum hoses, that we wouldn't use anyways, that are on the turbo one.
Old Mar 4, 2005 | 04:32 PM
  #113
lookslikeanevo's Avatar
got my IM today ....gonna get it ported next week....hopefully installed real soon....
this is a shameless plug, but if anyone wants a ported g94 IM....pm me....ill be doing them for cheap....
Old Mar 4, 2005 | 04:47 PM
  #114
Alchemist's Avatar
how much are you selling them for?
Old Mar 4, 2005 | 06:51 PM
  #115
Mitsiman's Avatar
Glad to hear the swap worked it was as I beleived.
There is no need for any porting as the 1.8 / 2.0 heads are identical no difference at all except for hydraulic V adj tappet in some models.
I highly recomedn this upgrade for everybody although the 2.0 throttle body is larger diameter so yu will need to port the manifold only at the throttle body flange plate and as you saw - change several bolts etc.
Nice cheap upgrade for everyone with goods results.
More importantly, it allows much larger gains for later mods as you need the extra air flow. This is one of the reasons I beleive the 2.0 has not responded as well to mods as the 1.8 model vehicles and is definitly a improver for the quarter mile times
Old Mar 4, 2005 | 07:14 PM
  #116
prolly gonna be around 190-200 shipped wih a $60 core charge
Old Mar 4, 2005 | 07:29 PM
  #117
rhyzin's Avatar
Mitsiman: wouldn't have done it if you haven't had said anything. most people believed the g94 intake manifold flowed better. thanks
  #118
kris is the dopest......
Old Mar 4, 2005 | 08:18 PM
  #119
No wonder Mitsu is in trouble financially when they do stuff like this.
Why after such a long run would you completely change a manifold when the existing one already works and better. I wonder how much they paid to have someone redesign it?
WADAD
Old Mar 4, 2005 | 09:44 PM
  #120
Alchemist's Avatar
Rhyzin- did you port the runners? I just got mine today and it looks like all they need is a slight touch up to remove the little bit of a burr that's at the runner opening. ******* this thing was a hell of a deal! I'm gonna have to spend some extra time getting the throat open to 61mm though
lookslike: have you ported one yet? How much are you porting the throat?
