Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
Mirage / Lancer Compatibility?
Old Apr 25, 2006 | 08:58 PM
  #31
Hotshot940's Avatar
outstanding, thank you
Old Apr 25, 2006 | 10:18 PM
  #32
grubiaco's Avatar
Hotshot you do have to change the throwout bearing. It should run you about 100 bucks.
Old Apr 26, 2006 | 08:52 AM
  #33
Tech@SA573's Avatar
I have an extra TOB for an 02-03 lancer for sale if you want it. Just P'm me
Old Apr 26, 2006 | 11:48 AM
  #34
Dr Crash's Avatar
thanks for the help Rhyzin!!
Old Apr 26, 2006 | 12:45 PM
  #35
rhyzin's Avatar
i do what i can
Old Apr 26, 2006 | 12:53 PM
  #36
Boeturbolancer's Avatar
You also asked about the phantom grip... it will work. However many end up blowing their trannies with it. The phantom grip is not an LSD of any kind. It's actually a coupler that binds the stock spyder gearing together making the car a positive drive. There is NO slipping. The stock spyder gears were not made for such force and will break at some point. It happens differently for people as it depends on the abuse the tranny has already seen and any manufacturer defects in the gears.
I strongly recomend not going that route unless you are willing to change out your tranny later.
Old Apr 26, 2006 | 02:49 PM
  #37
Silens's Avatar
$100 !?! my throwout bearing from the dealership for an 04 was $33 including tax!
I bought a phantom grip, and then decided i dont want to risk doing anything bad to the tranny (bought it all excited and then read about some problems people had with it, learned my lesson, do your research!!! ) so im trying to sell it now, anybody know any mirage forums? maybe ill try ebay .....
Old Apr 26, 2006 | 03:31 PM
  #38
Hotshot940's Avatar
yeah i heard that throwout bearings are like 30 bucks, i'll be pissed if i have to pay 100 for it
Old Apr 26, 2006 | 05:09 PM
  #39
04 uses old mirage bearing which is cheap... 02-03 use a bearing that also includes the slave cylinder and fork assembly. That one is expensive 70-100 depending on markup.
Old Apr 26, 2006 | 06:55 PM
  #40
comatose721's Avatar
i got mine for $100 for an 02
Old Apr 27, 2006 | 06:10 PM
  #41
Hotshot940's Avatar
son of a *****
Old May 3, 2006 | 05:33 PM
  #42
vikktorlv's Avatar
mirage parts
so clutch and flywheel from a Mirage will work on a lancer 02+, but for 02 and 03 you need a different TOB? is this correct?
Old May 3, 2006 | 05:38 PM
  #43
N1te's Avatar
Yes. That is correct.
Old May 3, 2006 | 05:47 PM
  #44
vikktorlv's Avatar
Mirage parts
thank you for clarifying that. Anyone pic a set they think will be best? as far as the flywheel and clutch. I am looking for something to handle some HP and hard driving, but streetable also
Old May 4, 2006 | 08:54 AM
  #45
N1te's Avatar
Turbo'd, or N/A? You should be able to get everything for around 700-800.
