reverse indiglo gauges
Old Oct 8, 2004 | 02:46 PM
irishlancer's Avatar
hey everyone.
i just bought reverse indiglo guages. does anybody else have them and how do you like them. also if anyone has any pics of them at night, post them. i would like to see them. i will post mine as soon as i get them in.
Old Oct 8, 2004 | 03:00 PM
RobertK's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=66953 has the basic how to on taking your dash apart, instead of swapping the cluster, just over lay it and be sure to not to mess up the needle, then just splice into a 12volt source.
Old Oct 15, 2004 | 03:46 PM
cautiontext's Avatar
This might help if you have not already installed. Click on page 5
or pm me for help
https://www.evolutionm.net/forums/sh...1&page=4&pp=15
Old Nov 1, 2004 | 10:32 AM
tidal's Avatar
i had a load of trouble getting mine in.. ended up giving up. how did you get them overlay to sit flush over the stock one without screwing up the needles.. mine kept rubbing on the overlay...
Old Nov 1, 2004 | 01:49 PM
You have to slide it from the right and point all the needls to the right. Its kinda tricky, but its the only way to get them on without fn up the needls. Mine rubbed on the 0-120 mph guage so I just got some double sided tape and put it between the stock guage and the reverse indiglo guage to pull it down. It worked and has been working for several months now nock on wood. .... You could also try to pry the needle up slightly with a flat head screw driver. I hope this helps bro....
Old Nov 1, 2004 | 04:38 PM
Evios's Avatar
The black piece you put back over the gauges push the pieces down, you shouldn't need double sided tape or anything else, and as for sliding the gauges over the needles, the hardest one I had was the speedometer, basically I started on the left, and let the overlay push the needle up - not forcing - until the black peg went through the hole, then just drop it and the needle should float down - same goes for the tac.
Old Nov 1, 2004 | 07:02 PM
tidal's Avatar
hey guys, just be REALLY CAREFUL WITH THE NEEDLES i eneded up having to get a new cluster put in.. was a nightmare... I might try again one more time.. i'm thinking of just selling it and recouping my losses.. put the cash into something simple.. like eyelids :P
oh and cautiontext.. thanks for the info im going to try it out tomorrow
Old Nov 2, 2004 | 05:50 AM
Centrylancer's Avatar
its a little tricky, took me 2 days to figure it out but they look great at night!
cautiontext
Dec 17, 2007 08:21 PM
sthiewes
Aug 30, 2004 12:08 PM
sthiewes
Aug 24, 2004 06:56 AM
TwoMix9900
Jul 8, 2004 08:12 PM
