View Poll Results: Rate this FlipFlop Trunk Modification
Top honors
18
52.94%
Good, but others are better
11
32.35%
Works, but design isn't so hot
5.88%
Stinks. Do not like it with green eggs and ham
8.82%
Voters: 34. You may not vote on this poll
Flip Flop Trunk Modification (new solution)
Old May 11, 2007 | 04:41 AM
  #31
mrtrunks's Avatar
wow that trunk came out great, better then buying the kit from autoloc. I think your car is looking good but you should take of the pin strips in my opinion, would make it look cleaner.
Old May 11, 2007 | 11:24 AM
  #32
bsc7080emn's Avatar
This vs. Autoloc
Thanks. I think the AutoLoc does not require any holes to be drilled but I could be wrong.. however this seems to work pretty well. You are right about the pin stripes... they will go away when I get a body kit... get a whole new paint job then to fix the crappy Mits paint job... they really cheesed on the paint on their cars. Hope the new ones coming out are better.
Old Nov 3, 2007 | 11:34 PM
  #33
kyled63901's Avatar
ok question about customizing the trunk. Has anyone ever heard anything about making a sideways trunk? What Im talking about is opening from the passenger side and making the driver side the pivot point. if any one has any comments please pm me.
Old Nov 4, 2007 | 06:25 AM
  #34
bsc7080emn's Avatar
Side Pivot
Anything can be done given unlimited funds... however what you might be able to do is cut the supports and insert long solid cylinder pipe on one side and a short one on the otherside... then remount the support pieces that were cutoff. Secure with pins so that they don't come loose. Remount the trunk and test that it opens and closes securely. When you want to display with sideways open style... open trunk, remove pins on driver side and passenger side... pull out slightly so that the short passenger pipe clears the support that its inserted into and left out... now we are pivoting on the driver side.... what you will need to address however is some way to keep the hood from swinging all the way up since the supports naturally want to pop up all the way.
Hopefully you followed that... I can picture it in my head... question is can you?
Old Nov 5, 2007 | 05:41 PM
  #35
bsc7080emn's Avatar
Custom Trunk
Follow Up...
Here is one approach, but taking it to the Extremes
http://youtube.com/watch?v=_tyY0SelAq0
Old Jul 4, 2008 | 01:26 PM
  #36
xxxchaos's Avatar
Arrow
Originally Posted by ThunderOZRacer
ok heres a question...IF those pins (the ones you are supposed to pull out) come out while ur driving for some reason or another will it effect anything?
No mine are snug in there. But you still have 3 other pins holding the trunk. Plus
my aluminum around the trunk is pretty snug so it won't move.
haulksmash
Dec 16, 2015 05:55 PM
boostedrb
For Sale - Part Outs
Jul 30, 2015 03:55 PM
Sangeof
44
Jul 8, 2014 09:58 AM
EVIL_EVO_VIII
Sep 24, 2005 03:40 AM
Kontradictions
May 4, 2004 06:13 AM
