4g63 Swap Thread(Mad_Canabice)
Old Nov 23, 2008 | 12:16 PM
  #46
Juan Martinez's Avatar
Originally Posted by MaD_CaNaBiCe
yeah i know about that but i trying to find out if the rack will work and the back engine mount
I would say the only person who could answer that would be MarkOJ1011.
Old Nov 23, 2008 | 05:28 PM
  #47
turbotime's Avatar
Rack will work, I just swapped my oz rack to a evo one.
don't know about the rear mount. I can say its definetly a diffrent mount, you can see on sits father forward.
evo rack installed above, lancer rack below. (not my car)
from what I see there isn't any difference between the evo subframe and the lancer subframe.
Old Nov 23, 2008 | 06:26 PM
  #48
Demon_ni2's Avatar
you sir r correct, subframes are almost identical, not counting a few holes.
Old Nov 23, 2008 | 07:00 PM
  #49
Did you notice a difference in steering and performance with the evo rack.
Old Nov 23, 2008 | 07:27 PM
  #50
OZ Rally's Avatar
Yes I want to know too...^
Old Nov 23, 2008 | 08:56 PM
  #51
MarkOJ1011's Avatar
Great... pictures of my car are everywhere.
Old Nov 23, 2008 | 10:54 PM
  #52
SlvrOz117's Avatar
poor mark
Old Nov 23, 2008 | 11:07 PM
  #53
MarkOJ1011's Avatar
Originally Posted by SlvrOz117
poor mark
Eh... my bad for posting them up anyway. I am not done with the build, therefore I keep things under wraps. I just let tidbits out every so often
Old Nov 24, 2008 | 06:26 AM
  #54
turbotime's Avatar
I haven't got the car on the road yet, I'll let you know. I've herd the evo rack is sharper though.
I will say that if your using the stock doughnut bushings on the evo LCA's you'll need to grind them down about a 1/4" since the lancer subframe is 1/4" smaller in diameter where they fit in.
Sorry mark for using your pic.
Old Nov 24, 2008 | 06:53 AM
  #55
MaD_CaNaBiCe's Avatar
so this confirms my question then that the evo and lancer subframe are the same and the evo rack will work with the lancer subframe? turbotime I assume you are doing this swap also is there a thread with your progress?
Old Nov 24, 2008 | 07:35 AM
  #56
turbotime's Avatar
yes this confirms it for you.
nope not doing the sawp, just doing a full front and rear evo exterior conversion.
Needed the rack and lca's to work with the evo fenders.
Dont have a build thread, figured I'd post pics when its all done.
I may take a stab at the 4g63 awd swap later though.
Old Nov 24, 2008 | 08:32 AM
  #57
Demon_ni2's Avatar
why spend time doing an awd swap?(major mods r needed) why doesnt anyone think about just using one of those b2 trannies from a gs-t eclipse.. its fwd and mates up to a 4g63..
Old Nov 24, 2008 | 08:36 AM
  #58
ThunderOZ's Avatar
Well if you are going to do that, you might as well just used the 4g69 tranny or 4g64 tranny.
Old Nov 24, 2008 | 08:41 AM
  #59
Demon_ni2's Avatar
why would you use a 69/64 tranny. they dont mate up to an evo motor. the gs-t eclipse tranny does and comes off of a 4g63 motor.. only problems i could think of might be axels, but still 2000x cheaper then fabbing up a whole rearend.
Old Nov 24, 2008 | 08:44 AM
  #60
ThunderOZ's Avatar
Yes the 64/69 transmissions do mate to the evo motor.
There are evo's running 64's with their own transmission.
There is also a ralliart around here with the 63 motor on the 69 transmission... Because they mate to each other.
