4g63 Swap Thread(Mad_Canabice)
Old Nov 24, 2008 | 08:56 AM
  #61
Juan Martinez's Avatar
Originally Posted by MarkOJ1011
Eh... my bad for posting them up anyway. I am not done with the build, therefore I keep things under wraps. I just let tidbits out every so often
But your pictures inspire us so. Without them, we are hopeless, lost. Do you plan on sharing your build once your done?
Old Nov 24, 2008 | 12:56 PM
  #62
MarkOJ1011's Avatar
That is my objective sir! I will let a few tidbits out though... I'm sure a few of you guys are in the SCLC forums... I do have a project thread there. The only thing I ask is that no one abuse my build pictures. My friend and I have been working really hard to make this happen and it took a lot of research and development to get to where we're at, at this point.
The AWD conversion is pretty much in. I just need to finish up on a few other details. I am using Outlander components in the back... it all bolts up.
Old Nov 24, 2008 | 01:02 PM
  #63
MaD_CaNaBiCe's Avatar
so outlander components bolts right up in the lancer or ab work is needed?what kind of components are u referring to and can u send the link to the build thread?
Old Nov 24, 2008 | 01:07 PM
  #64
MarkOJ1011's Avatar
Fab work is still required... the shock tower/mounting point rubs on the inside wheel area. As you all know, the EVO's shock mounting point sits higher than the base Lancer's. It had to be moved... so we made an inboard cantilever suspension setup.
In due time I will make a build thread here. Don't worry.
Old Nov 24, 2008 | 03:36 PM
  #65
Do you have a link to your build thread on sclc.net? I've looked all the other day and couldn't find it.
Old Dec 17, 2008 | 10:50 AM
  #66
r8ednxt's Avatar
bump for updates???
Old Dec 21, 2008 | 03:41 PM
  #67
Originally Posted by r8ednxt
bump for updates???
i am on vacation and don't have everday access to a computer i have just finnished purchasing everything for my head and in the process of sourcing an evo 8 bottom end due to the fact that the evo 6 bottom is too much hassle to get parts and as you guys can see i am starting from the ground up with this motor i won't be back home until next month so i'll have pics up then
Old Dec 22, 2008 | 06:49 PM
  #68
pdizzle's Avatar
this an amazing build that your doing, im subscribing!!
Old Dec 23, 2008 | 10:19 PM
  #69
smartidiot2122's Avatar
if you can dream it, you can do it!
Old Dec 28, 2008 | 09:45 AM
  #70
updates will be up at the end of january when i get back from dominican republic
thanks for the support guys
Old Jan 26, 2009 | 08:44 AM
  #71
Ok guys i am back from my 3 week vacation and i'm broke lol here is an update since i've been gone i finally have all my parts for the head except the (cam gears) i have now realised that some of the parts such as the right engine mount bracket from the evo 8 that bolts to the block won't work with evo 5 block so at this moment i have decided to put the block i have for sale.
Old Jan 27, 2009 | 01:40 PM
  #72
ThunderOZ's Avatar
Ok great keep us updated.
Old Jan 27, 2009 | 03:34 PM
  #73
don't worry i will atm i am working on getting an evo 8 block because the brackets i have cannot work on the evo 5 block
Old Jan 28, 2009 | 11:43 AM
  #74
*update*Well I got engine mount and test fitted it to the stock lancer crossmember it bolted up with no problem this may be a good help to some of you who were not sure about this
I also got bored and painted my valve cover to match my car with plasti coat high temp paint and clear.
As most of you may have realised at the beginning of this thread that i got a scrapped motor
so i had to purchase just about everything to put this motor back together so here are the rockers,cam caps,springs and reatiners i just received also.may start assembling this as soon as next week if all goes well
Old Jan 28, 2009 | 12:12 PM
  #75
OZR_Lancer's Avatar
niice
