Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
FWD Transmission Removal
Old Feb 23, 2014 | 06:57 AM
  #46
bzmotoninja83's Avatar
IIRC, depending on the year, the clutch tob is bolted to the trans with 3x 10mm bolts. If its the later years, using a standard style slave cyl, you should still be fine.
The last vehicle I ever had like what you describe, was a 1997 Isuzu Rodeo with a pull type clutch
Old Feb 23, 2014 | 08:42 AM
  #47
corndog17's Avatar
anyone know where to get a used 5 speed for the oz? I lost first gear.
Old Feb 23, 2014 | 05:35 PM
  #48
eusgen's Avatar
www.car-part.com is the only place I have found one, unless your local junkyard happens to have a lancer lying around.
I have to ask around and do more research but I would think any F5M42 transmission would have the same gearing, some just have different styles of slave cylinder or mounting possibly, etc.? something to look into, you could have a trans shop swap the gears out. The trans shop I took mine to is looking for a 3rd gear (possibly 2nd as well) for mine at the moment. Will have to ask tomorrow how that is going.
Old Feb 27, 2014 | 06:48 PM
  #49
03lanceres916's Avatar
Are there any transmission swaps for an es?
kickin wing
276
Mar 10, 2025 06:55 PM
CrypticApathy
Southeast Region
Dec 7, 2016 09:29 AM
jimbo74
80
Apr 23, 2016 01:52 AM
Brandon Blank
Jan 20, 2016 02:56 PM
ZombieBatman
Outlander Sport
73
Dec 30, 2015 09:56 AM
