Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
stock tranny
Old Jul 17, 2008 | 12:01 PM
njleeson's Avatar
stock tranny
i have kinda been doing a couple little mods on my car, and my friend drives a gli. he said i would prolly have to replace my tranny when i turbo because the stock tranny is rated for a low horsedpower. is this true?
Old Jul 17, 2008 | 12:05 PM
bcollinstex's Avatar
Oh yeah. Check http://www.roadracemotorsports.com/ they have a stage 2 kit that can handle a good amount of power.
Old Jul 17, 2008 | 01:04 PM
JRR's Avatar
JRR
definatley put in a different clutch and while yur in there do the flywheel as well. i did the act mb8-xtss and the clutchmasters flywheel from rrm. ince you get it broken in its a blast!
Old Jul 17, 2008 | 01:08 PM
JRR's Avatar
JRR
http://www.advancedclutch.com/141723...2.0L_N_FI.html
http://www.clutchmasters.com/shop/?p...006&AppID=6864
here is more information from what i put in.
Old Jul 17, 2008 | 01:12 PM
Here's something to get you started on turbos.
https://www.evolutionm.net/forums/sh...d.php?t=215724
Old Jul 17, 2008 | 01:52 PM
doctorjon's Avatar
im running turbo on stock internals, thats including my tranny and clutch.
I'm just daily driving it. I replaced the clutch with a OEM clutch like 5,000 miles before i did a turbo install and its runs perfect.
mcgarvey's Avatar
He didn't ask about the clutch. He said will the tranny handle it. You could probably double your power output and be safe (approx 200 whp). More is probably possible, I don't know.
Old Jul 17, 2008 | 01:57 PM
doctorjon's Avatar
oh my bad, other people were talking about replacing clutches and all that. I think if you don't rag your car out you won't need to replace the tranny. i'm not sure what im pushing cause i haven't dynoed yet but i know im hitting atleast 190 with my setup
Old Jul 17, 2008 | 02:12 PM
Isn't the clutch part of the trans? Then yeah, the comment about upgrading the clutch is valid.
However, the trans itself probably can't handle more than 200, stretching to 250 if you are doing high rpm launches and using LSD. I'd say if you are doing alot of heavy duty racing, then you want to beef up the rest of the trans.
Old Jul 17, 2008 | 02:18 PM
lancer2show's Avatar
the stock manual tranny can do 300hp fine.
the auto is a different story. id say 240-250.
Old Jul 17, 2008 | 02:19 PM
doctorjon's Avatar
Yeah, just gotta have a good clutch in and make sure you have brake fluid or else you won't be going nowhere lol. I've seen that happen when people think their clutch is gone and goto check the brake fluid and its empty lets just say i know someone
tbryant0226
Jan 13, 2014 07:51 AM
08 Evo X MR
May 22, 2009 02:05 PM
evo05VIII
13
Mar 6, 2009 03:47 PM
evo9ben
Sep 1, 2008 03:19 PM
gen3eclipsegt
May 18, 2007 02:56 PM
