Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Dropping Tranny
Old Apr 14, 2016 | 10:08 PM
  #76
jimbo74's Avatar
Veteran: Air Force
I ground the gouge flat, cleaned everything up with brakes parts cleaner, including the outside of the case, then put sealant on the plug, then hit it in with a rubber mallet, once it was flat, used a huge socket around the edges, then coated around the edge to the case -- I will be letting it cure for several days in the garage while I am waiting for my new slave to come
Old Apr 15, 2016 | 04:30 PM
  #77
jimbo74's Avatar
Veteran: Air Force
got my slave!
to the batcave!
Old Apr 16, 2016 | 08:17 PM
  #78
jimbo74's Avatar
Veteran: Air Force
so..... it's running!!!!!!
got 12 miles on it right now..... no issues.....
clutch feels decent, no leaks that I can see right now......
gears feel tight to go in, but that could jsut be because of the new synchros
also, I ended up putting in brand new fluid today also
I vacuum bled the clutch this time
Old Apr 19, 2016 | 08:09 AM
  #79
jimbo74's Avatar
Veteran: Air Force
have over 70 miles as of today, I will be rechecking it for leaks in a little while... last time I checked it was all good though
I really think the leak was because they gouged the case/seal by popping it off from the side, and treusing it, then trying to hide that, with rtv.....
makes me wonder if the builder cheaped out on otehr stuff also..... the gears are starting to feel a little less notchy, and a little more normal though, so that's good
Old Apr 20, 2016 | 01:34 AM
  #80
jakermeister's Avatar
Good to see you got everything worked out.
Old Apr 23, 2016 | 01:52 AM
  #81
jimbo74's Avatar
Veteran: Air Force
so I don't actually recall how many miles are on it right now, but.... I am somewhere in the realm of 450 miles on it, so I will be popping it open soon and look at the fluid, and change it if I thin kit is gross.....
EvoInSoCal
31
May 23, 2019 09:30 AM
MarkChamorro
340
Aug 15, 2013 09:23 AM
Sailorgoon
Lancer Engine Tech
Aug 25, 2003 11:02 AM
Sailorgoon
Lancer Troubleshooting
Sep 25, 2002 08:49 PM
