Flat spot
Old Feb 15, 2003 | 10:36 PM
Rallywiz03's Avatar
Question Flat spot
ok here is one for the brains in here. during 2ng gear about 4500 rpm and 3rd gear same rpm's, i am experiencing what seems to be a flat spot .. now this doesn't happen all the time but frequent enough. i only have 3000 miles on my car and it didnt start until about a week ago, any one knowing anything about what might be wrong so i have a good idea when i can get it back to the dealer what to tell them. thanks alot
Old Feb 15, 2003 | 10:39 PM
KMcW's Avatar
Is your car stock?
Old Feb 15, 2003 | 10:41 PM
Rallywiz03's Avatar
ya its stock , i had an intake and thought it might be the problem but i put the stock back on and it still does it
Old Feb 19, 2003 | 12:42 PM
pickleknock's Avatar
that is kinda wierd, thats usually when the torque kicks in, on my car anyway. ive only got an intake. could be something with the fuel system?
Old Feb 19, 2003 | 01:04 PM
Crzylizard's Avatar
It could be a problem with the car not being completely warmed up...i dunno. I would say have someone take a look at your fuel delivery system that would be a good start
Old Feb 19, 2003 | 01:17 PM
RacinMylancer's Avatar
maybe a computer issue? try disconnecting the battery for 15 minutes (to reset the ECU), then reconnect and let the car sit running for 10 minutes so the ECU can recalibrate, then drive it and see if the problem persists.
Old Feb 19, 2003 | 02:54 PM
pjal84's Avatar
I don't think the third gear flat spot is an issue. With the power available from the motor, the pull will end at roughly the middle of third gear. As for second, it should pull relatively well until the end. An intake will help power delivery in third and should carry you all the way to max torque and 4th will pull only marginally harder towards about the middle of the gear.
Old Feb 19, 2003 | 03:44 PM
on3ofak1nd's Avatar
So are you saying in you should shift from 3rd at around 3 grand because the rest of that gear has no more pull? im not disagreeing or agreeing im just trying to make sure i understand what you're saying...?
Old Feb 19, 2003 | 03:54 PM
reddog's Avatar
Paul is correct, my car drives exactly as he described. Plenty of torque all thru powerband in 1st and 2nd and midway thru 3rd. After that I can put the pedal to the metal and not much happens. Not much high end torque at all. If that's what you are talking about, it's normal.
Old Feb 19, 2003 | 06:41 PM
mobius97's Avatar
That sucks the torque runs out........and ya half to shift at 3k..man I wouldnt like that too much, but then again my car do 72mph in second tho its not recomended hehehe!!!!!
Old Feb 20, 2003 | 02:02 AM
Rallywiz03's Avatar
ok maybe this sounds better to you guys, i dont think i explained it well. you know when your sitting at idle with your ac on lets say. And when the ac pump kicks in your idle drops just a split second ? On now put that in the equasion @ 3k rpm area while accelerating. its just a cuick miss sort of as if the ac pump was kicking in even thought it is turned off. Does that help ? and thanks to all of your advice guys
Old Feb 20, 2003 | 02:03 AM
Rallywiz03's Avatar
ohh and it is significant enough to feel but not hurt acceleration enough to worry about , just a new car and all im sure you all understand concerns
r2kbug
Dec 5, 2007 09:10 PM
voidhawk
Jan 16, 2007 06:10 PM
lucentex
Lancer Troubleshooting
31
Oct 23, 2006 11:02 AM
galvitron
Mar 23, 2006 01:08 PM
trev0006
43
Jul 24, 2003 08:43 PM
