After a week of trying !
Old Jun 5, 2006 | 09:13 AM
comatose721's Avatar
Originally Posted by gregivq
^that's really messed up, I feel for you man.
i'll second that. i just had a similar problem straightened out 3 weeks ago. they cut off my stock flange and welded the cat back directly to the cat. it isn't pleasant by any means. good luck with that. try to get them to fix it out of their pockets; not yours. it was their mishap.
Old Jun 5, 2006 | 03:04 PM
Mr. AutoLS's Avatar
taking it to the shop was the last thing i wanted to do, they charge my *** of
Old Jun 5, 2006 | 03:06 PM
Mr. AutoLS's Avatar
Originally Posted by N1te
It's a b*tch. Unfortunately, almost all of us who have done exhausts have gone through this, and quite a few of us have had to go through the same exact ish with that bolt.
If you were closer to DC I'd get you in a shop with a lift and for 4 bucks we could get that sucker off.
I wish i can cut it i guess i cant though right? blow torch would make it lose in other words your saying and i would be fine?
Old Jun 5, 2006 | 03:17 PM
Alchemist's Avatar
Closed end wrench. PBlaster. torch. Rubber mallet. Leather gloves. and while you're at it get a 7/8" line wrench for the O2 sensor. (looks like a box wrench with a slit cut out... you'll see). Some sort of cheater bar or a long socket-type breaker bar would be helpful. Physics is your friend.
Put on leather gloves. Hot things will burn you.
Heat the part that moves (nut) just a little. This will open the threads some and make the PBlaster more effective.
Spray with PBlaster. Do not place yourself directly underneath the nut at this point. The PBlaster will be hot and will drip onto whatever is below it- your face, abdomen, crotch, whatever. Best to let the garage floor take the hit.
let sit for a few minutes.
Put wrench on nut, push up (or pull down depending on which nut it is). Left-turn= loose.
If no go, strike with mallet.
Repeat above steps until successful.
You can heat the nut to red- that will really make it expand. But in all likelyhood the threads will bust out and you'll have to get a new nut. Ask me how I know. Do not touch stuff that it red hot or that has recently been red hot. You will get burned.
Old Jun 5, 2006 | 09:48 PM
N1te's Avatar
Alchemist in for the save!
Boostfiend
Mar 9, 2010 09:03 AM
Meevo
Mar 2, 2009 02:40 PM
Inflation
Oct 14, 2008 01:56 PM
jmtx86
19
Aug 14, 2008 11:19 AM
Celica2EVO
Oct 8, 2007 01:07 AM
