Help reversing in 5spd
Old Jun 10, 2003 | 08:00 PM
i_love_spool's Avatar
Ok, this is a pure n00b question, but I've never driven standard until a few days ago. I can start off pretty well and change gears well too, the problem is reversing.....
help, before i wreck something...or look like a fool in front of my friends at an up coming meet.
Old Jun 10, 2003 | 08:11 PM
Sailorgoon's Avatar
What trouble are you having exactly?
Since reverse is typically used to travel very short distances, it's usually OK to reverse while slipping the clutch, i.e., not letting the pedal all the way out.
If you try to release the clutch completely, you will usually have some bucking or you will stall.
If you have trouble putting the car in reverse, make sure you are at a full stop, press the clutch to the foor, place the gear in neutral and release the clutch. Then press the clutch again and try to engage reverse. It will usually take some effort, and it will be stubborn, so you don't stick it in R without really wanting to.
If you hear the gears grind, slow down and take your time. Make sure you depress the clutch fully.
Reverse is hard, but these cars handle it pretty well. A little practice should do the trick.
Old Jun 10, 2003 | 08:16 PM
Thanks....its just backing into parking spaces and the driveway....i alway back into where im parking so its easier to get out....and i guess i have just let the clutch out too much, didn;t know i could slip it...THANKS
Old Jun 10, 2003 | 08:32 PM
Sailorgoon's Avatar
Just make sure you don't rev up too high, because slipping will wear out the clutch surfaces.
You shouldn't need more than 2500 on the tach, and that's probably a bit excessive.
Old Jun 11, 2003 | 08:11 PM
kbadboy's Avatar
wow just take your time i seem to need a few more rpms to get it going soo yea !!! good luck
Old Jun 11, 2003 | 08:19 PM
Just went out and bought a car cover....backed the car into the driveway when I got home....no stalling at all....THANKS.
now if I could only get going forward perfectly w/o stalling 1 out of every 5 times.....lol...im letting off the clutch too fast
Old Jun 11, 2003 | 08:22 PM
zlancer's Avatar
yup jus take your time. it will eventually come to you and will be like second nature.
Old Jun 11, 2003 | 08:37 PM
EVO SPECIALIST's Avatar
I know how you feel,I learned how to drive a 5spd when I got into car sales,imagin that test drive
Old Jun 12, 2003 | 01:08 AM
blaze_125's Avatar
You know what? I took driving lessons on a manual tranny. The lady kept telling: "Release the cluth and then give it some gas"
Well, that's freakin bullsh*t. When I baught my Lancer, my cousin sat beside me and told me to do it this way...
Rev up between 1000 and 2500 Rpm and then let the cluth slowly go. Never stalled since then.
Old Jun 12, 2003 | 01:13 AM
TwiNpnOy84's Avatar
Thats why my cousin told me, and it worked for me too
Old Jun 12, 2003 | 01:14 AM
insomniac_evo's Avatar
do the same thing when you're in 1st gear, whats so hard bout that
Old Jun 14, 2003 | 01:33 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I don't know about others, but I rarely use the gas when backing into or out of a parking space. I just feather the clutch until it's where I want it.
fas-n-furyus
12
Jul 14, 2018 09:26 PM
Peage
Mitsubishi TC-SST Discussion
Jun 20, 2016 11:33 AM
splay
16
Jan 10, 2013 04:29 PM
MR LuKe
10
Oct 30, 2010 08:34 AM
M4Lki3r
Feb 27, 2009 08:15 PM
