Light on the Trip Odometer
Old Feb 24, 2008 | 10:23 AM
Mike2854's Avatar
For a while now, the light on the trip odometer s not working at night. The rest of lights are working (headlights, dome light, other interior lights). Is this a bulb issue or a fuse problem? If it is a bulb issue, is it hard to fix? Do I need to take the dash apart or how should I go about it? This is for a 2002 Lancer ES.
Thanks in advance.
Old Feb 24, 2008 | 01:17 PM
awdlancer's Avatar
i have the same problem
Old Feb 25, 2008 | 12:05 AM
02_lancer's Avatar
i have the same car and the same problem haha
Old Feb 25, 2008 | 12:20 AM
EvoKnievo's Avatar
i dont have a lancer but this is a very common problem for our clusters.
its the bulb.
it is a very easy fix.
there are two screws on the top of the black plastic piece that goes around the cluster
see the image for the two screws if you are not familiar with them
(#2, screw b) x2 ((there philips))
now pull that straight out.
you will now see 3 more philips screws holding the cluster to the dash.
2 on top 1 on bottom.
unscrew them and the cluster will have some slack (finangle) it forward by primarily tilting the bottom forward. reach your hand behind and there are two clumps of wires (unclip each clump) and pull the entire cluster forward and out.
on the back of the cluster there are 4 or 5 small philips screws holding a brown plate to cluster.
unscrew them take the brown thing out.
now you will see the small black bulbs, locate the one that is burned out and replace it.
any dealer will have the correct part # and there twist lock style
EvoKnievo's Avatar
i forgot te image my bad
Old Feb 27, 2008 | 11:11 PM
02_lancer's Avatar
cool cool thanks for the pic and the walk through
Old Mar 22, 2008 | 10:38 PM
oLacy's Avatar
This is happening to mine too...
i just had a new head unit put in so I don't know if wires got touched or pulled.
Did you do anything to your car when you noticed the problem or did it just happen randomly?
Old Mar 23, 2008 | 09:53 AM
mstove's Avatar
Wow, I didn't figure it'd be that easy to get the instrument cluster out/in. Thanks for the detailed info.
TrappEvo355
Jun 9, 2012 05:43 AM
RenosEVO
Feb 12, 2012 09:47 AM
D Grade
Jan 12, 2012 05:53 AM
shrtstuff89
May 8, 2011 07:49 PM
Hen5000
Jul 9, 2008 06:33 AM
