timing with stage 2 cam
Old Mar 25, 2008 | 01:05 PM
kansaslancer02's Avatar
I replaced my timing belt and did the timing like I should: Put the crankshaft at the TDC mark and put the slot in the cam gear at the 10:30 position and now its not starting. The stealership says its timing but they won't touch it because of the aftermarket camshaft and cam gear. Is there any difference with setting the timing when you have a stage 2 cam?
Old Mar 25, 2008 | 02:14 PM
SLVROZ_03's Avatar
It should start at 0 degrees. Try setting it up using the stock gear, then swap it out when you get the timing set perfectly.
Old Mar 26, 2008 | 07:29 PM
thanks but I have a lightened crank pulley and there is no timing mark on there. I set the mark that is on the crankshaft gear to line up with the "T" on the plastic cover. I dont't think this is correct because my car isn't starting. Any help? Also I don't have my original crank pulley so I can't cross reference.
Old Mar 27, 2008 | 12:22 PM
SLVROZ_03's Avatar
What I meant was that your cam gear was off. When I did my T-belt change, I aligned the keyway of the crank gear with the arrow on the plastic cover. Then the cam gear (mine was stock) I just aligned the arrow as well. GL!
Old Mar 30, 2008 | 10:54 AM
thanks got timing done
Old Mar 30, 2008 | 10:58 AM
but I do have another issue. The car wont start. I know its fuel related because if I spray some carb choke cleaner into the filter it will stay running for about 10 seconds then tries to die again until I spray some more. I have some fuel injectors I'm going to put in today to see if thats the problem. Fuel pump is new and i cleaned my crank sensor while I had the plastic cover off so I don't think its either of those.
If not injectors, what else could it be?
Old Apr 10, 2008 | 02:49 PM
schang_18's Avatar
check the crankshaft sensor
there are two other possible probs
the crankshaft sensor tells when to send in the fuel to feed the engine.
maybe it got damaged or something, just check it
it could be the cam sensor too, but i highlt doubt it
also check out your fuel pump
gl
Old Apr 10, 2008 | 03:52 PM
SLVROZ_03's Avatar
Well, since it'll only be at idle try the stock 245s and see what happens!
mazda8799
21
Apr 12, 2011 12:48 PM
1 WICKED EVO
May 10, 2008 07:33 PM
mchuang
Sep 10, 2006 01:59 AM
Evil EVOIX
Jul 30, 2006 05:45 PM
bigmike9726
19
Feb 21, 2006 07:23 PM
