Is this an exhuats leak??
Old May 30, 2008 | 11:20 AM
Geo_lancer's Avatar
my header was taking off due to the weild that it gotton weak.. so i had to put stock header on.. but i notice i still have a flickering noise.. not as loud as before but its annoying bc u could hear it outside especially when i puch it... i took off the header and put it on again and still.. i check the connection underneath and nothin.. i got a vid to see ur guys input.. i be damn if it the lifters were causin such noise..
http://www.filefactory.com/file/417ae1
the file is only 270 kb
Old May 30, 2008 | 11:58 AM
ambystom01's Avatar
Did you replace the gaskets?
Old May 30, 2008 | 01:52 PM
Geo_lancer's Avatar
i put the stock header gasket (which is in good condition) on bc the one that came with obx header was bad already.. the gasket between the downpipe and testpipe and the testpipe to cat back havent been changed..
Old May 30, 2008 | 01:53 PM
ambystom01's Avatar
Change those gaskets and see if that helps.
Old May 30, 2008 | 01:56 PM
Geo_lancer's Avatar
ok i give it a shot to see.. thanks for the help
Old May 31, 2008 | 01:57 PM
Geo_lancer's Avatar
i disconnected the stock header from the downpipe and i turn it on... i know it sounds loud but i did it to see if the flickering noise would quite down.. despite the rumble the car makes when disconnected from the downpipe.. it still made the flickering noise.. so i know now its not the gasket.. its sounds like its coming from the head....
what i am gonna do is disconnect the header and turn it on.. i know that crap is gonna sound loud but its to see if i could hear the flcikering noise.. if i do.. what might be???
Old Jun 3, 2008 | 07:14 PM
Geo_lancer's Avatar
prob fix: the stock header and gasket were in good condition. from research and opinion from a mec .. the sypmtons seemed as if the car was low on oil but when i check for leak.. the oil filter had a leak an oil change later and a addtive.. car is sounding beautiful and quiter than ever..
Old Jun 4, 2008 | 05:13 AM
Jehuty's Avatar
Good stuff bro
thewiz11144
Lancer Engine Tech
Dec 18, 2011 11:21 AM
Walkingchaos
23
Nov 26, 2009 12:08 PM
RedOz03
Lancer Engine Tech
14
May 8, 2008 10:40 PM
David Buschur
130
Mar 12, 2008 09:43 PM
QuakerOatMan
Lancer Troubleshooting
11
Sep 14, 2002 07:20 AM
