running guage wire thru firewall
Old Aug 26, 2003 | 09:32 PM
gokusupersaiyen's Avatar
Hi all
im installing a few gauges in my car
and was wondering where everyone
else ran their wiring thru the fire wall
any place easier than another?
Old Aug 26, 2003 | 09:59 PM
ghostrider's Avatar
Run a search next time!
There's a plastic boot that you can drill through on the driver's side. You can follow the hood relase cable to find it, or better yet check my registry cuz I have a pic of it. The wiring will run inside the driver's side front quarter panel.
Old Aug 26, 2003 | 10:07 PM
thanks captain
Old Aug 26, 2003 | 10:12 PM
ryancb's Avatar
you can do that or go thru the pass side takes a bit more wire but easier 2 get 2
Old Aug 26, 2003 | 10:17 PM
imapunkclaimer's Avatar
Do it this way:
Take off the stuff around your wheel well, then youll see a rubber grommit near the door, lift a corner of that up and put the wire through it. Dont take the rubber piece out cuz its hard to get back in.
Old Aug 26, 2003 | 10:32 PM
SICKdimension's Avatar
I ran mine through the driver's side fender, then through the rubber hose that connects the door to the body. Here is the how-to posted in the Audio section.
https://www.evolutionm.net/forums/sh...threadid=26905
This is only good for 1 wire though.
Old Sep 3, 2003 | 01:34 PM
mobius97's Avatar
or just go thru the steering boot. thats how my boost gauge is ran.
Old Sep 3, 2003 | 01:41 PM
cerfur's Avatar
i have a decent amount of wire run through the hole in the passanger side its in the corner its a good 3/4 or inch wide what i did was put some loom though the hole and i runn all my wires through it its simple then you can run the wires where u need them
JRally
May 10, 2016 12:26 PM
JUS4SHO
11
Jun 29, 2015 01:47 PM
johnd651
Jun 27, 2007 02:19 PM
drunutz
Lancer Engine Tech
46
Mar 30, 2004 08:55 AM
ryancb
Aug 6, 2002 09:04 AM
