lancer idle problem
Old Apr 25, 2010 | 11:15 PM
r_hickein's Avatar
lancer idle problem
car idles at 2000 rpms when i start my car. this continues until the car is warmed up then it drives normally. i went to autozone and the guy told me i had a vacuum leak but when he came out to listen to it he said he didnt kno what it was. help please!
Old Apr 26, 2010 | 12:05 AM
T2Small's Avatar
FIAV failure most likely.
Old Apr 26, 2010 | 01:05 AM
r_hickein's Avatar
how would i fix that if thats what it is?
Old Apr 26, 2010 | 11:31 PM
T2Small's Avatar
Either replace the FIAV, or the entire throttle body. You can probably adjust it too, but my experience is with newer and older versions of your car, not what you have.
Old Apr 27, 2010 | 02:16 AM
turbolancer02's Avatar
2k for 30 seconds or so is normal if the ecu has a cold flash , if anything its likely your idle speed control on the t/b search on here for how to clean the throttle body, the fiav is non adjustable for the diy'er
Old Apr 27, 2010 | 06:25 PM
r_hickein's Avatar
ok ill check that out. thanks
Old Apr 27, 2010 | 07:11 PM
slatermvp's Avatar
whats a fiav?
Old Apr 27, 2010 | 07:43 PM
r_hickein's Avatar
fast idle air valve
khalid.alghawas
Apr 8, 2013 03:18 PM
Frew
14
Sep 1, 2012 11:56 AM
jellotroz
Jun 16, 2012 07:30 PM
fengzhaoxi
Apr 3, 2010 10:54 PM
damstr
Jun 26, 2008 11:36 AM
