Squeaking w/ AEM CAI
Old Nov 12, 2003 | 05:21 PM
drummerjun's Avatar
Question Squeaking w/ AEM CAI
Ok so I installed my AEM CAI, with Kareem's help (THX BTW).
Everything is good except for one thing.
There's this *squeaking* coming from the filter area everytime the car
1) starts
2) shuts off
3) changes gear
4) shakes.
It's really not big a deal, the car goes fine, the intake sounds good, but it really is getting annoying.
Do you guys with AEM CAI also have this prb?
Old Nov 12, 2003 | 05:38 PM
blackmantis's Avatar
check all the hose clamps to make sure they are tight then check to see if it is rubing on anything
Old Nov 15, 2003 | 10:05 AM
SSABII's Avatar
i know with mine it squeeked because it was hitting the big plstic box type object that surrounds the battery. i had to re bend the whole bracket underneath just so it moved over. it bugged the crap outta me...hope that helps but check to see if its rubbing there.
Old Nov 15, 2003 | 10:42 PM
XTXANDY's Avatar
My SRI sqeeks at the same times, or it sounds like its from that area. Mostly when its cold too. Drives me crazy.
Old Nov 20, 2003 | 11:39 AM
Bruce3's Avatar
ok the same thing happend to me when i installed mine too! its a black bracket that held the stock air box, i think its held in place by two screws and attached to a cable. remove the two screws and you can just pull it off the cable. hopes this helps, good luck!
Old Nov 20, 2003 | 11:43 AM
02izzel's Avatar
hmm..mine makes a sort of squeeking noise, but only when i shut the engine off. never when im shifting gears.
im about to go outside and check all my clamps and such.
Old Nov 20, 2003 | 11:48 AM
babyboba29's Avatar
are any of your cars drops with eibacj or progress springs? that could be the squeeking that is coming from the wheel well, but it sounds like it may come from the CAI. i have the CAI and progress, andi found out its the springs and not the intake.
Old Nov 21, 2003 | 12:59 AM
drummerjun's Avatar
Turns out it's the intake rubbing the stock air box holder which I didn't take out..hehehe...problem solved.
Thanks for the inputs..
Peter Gallup
Sep 12, 2011 12:42 PM
cedes14bamg
Lancer Engine Tech
Nov 9, 2010 07:11 PM
Mc-Roux
Lancer Engine Tech
May 18, 2010 07:37 PM
Ralli04
May 7, 2007 05:29 PM
grubiaco
Apr 17, 2006 12:09 PM
