08 ES Sticky Transmission 5spd
Old Sep 2, 2012 | 01:59 PM
conQUIStador's Avatar
I've noticed lately within the last 200-300 miles when I shift from 1st to 2nd, I have to shift harder just to get into gear. If I don't, the gear usually sticks in between 1st and 2nd gear. The car has 66k miles, I bought it with 54k miles. Do I have to replace the clutch?
Old Sep 3, 2012 | 09:04 PM
Any help would be appreciated. Thanks.
Old Sep 5, 2012 | 09:20 AM
CamShaft's Avatar
if its only a problem shifting between those two gears, then it would point to a transmission issue (synchro worn). How is downshifting from 2-1?
Old Sep 7, 2012 | 05:58 AM
2 to 1 is fine. 1 to 2 is rough. I'll get the tramission looked at. Synchro is pretty serious?
Old Sep 12, 2012 | 03:18 PM
CamShaft's Avatar
It will be a transmission teardown and rebuild. Don't skimp on any parts that look questionable. Yes it will be a bit pricey. It does sound like your second gear synchro, but do get it diagnosed by a professional before jumping to a conclusion.
What about gears 3 to 2?
ThugzNHarmony
Mitsubishi TC-SST Discussion
26
Feb 23, 2012 09:00 AM
aycynokia
May 10, 2011 05:33 AM
EvoX-11
12
Nov 16, 2010 06:47 AM
ej257gd
208
Oct 1, 2008 06:24 PM
evo_skillz
Dec 30, 2006 06:09 AM
