post all STRANGE NOISE complaints here
Old Mar 19, 2011 | 11:28 AM
  #151
lancer586's Avatar
Originally Posted by piledrivingdude
I have Mitubishi Lancer 2003 and the motor squeals when I start it up. It stops after a few seconds. I've checked the belts and they seem snug enough.
Bro it's probably the belt even if its snug enough. My car use to make that noise all the time when i start up but i was like who cares lol because it was snuged enough also. So one day my car dies at the corner store and it wouldnt start. Jump start it and it work fine but it keep dieing when i turn off the car and try to turn it back on. Thought it was a bad battery and was gonna replace it untill i see that my belt for the alternator has a big *** rip in the middle. Didnt think that the car would not start because of a belt so i took the alternator out and check it at autozone and it was working perfectly. So i was like what the heck i replaced the belt and it still wouldnt start using a jumper box. So i got frustarted and hook cables up to my dads van and Waaaa Laaaaaaa. Its up and running and never died again
Old Mar 20, 2011 | 12:20 AM
  #152
03lances's Avatar
Yup that damn alternator belt seems to need tightening every few months for me I dont know why but I just tighten it up every few months when I hear it starting to squeal and Im good. The belt is less than a year old too. Had the same issue with the last belt
Old Jul 8, 2011 | 09:14 AM
  #153
spc2125's Avatar
So the other day I was in my house and all of a sudden i hear a noise outside. It was hot out and my horn was i guess stuck and was causing it to constantly honk. Has anybody else had any problems with heat and their horn going off or getting stuck?
Old Jul 9, 2011 | 09:29 PM
  #154
spc2125's Avatar
bumpp
Old Jul 21, 2011 | 12:49 PM
  #155
jaybo1977's Avatar
I have an 04 es that now makes a whining noise? Sound like a run a charger on it, but no power adders are in my car. Only noticeable when car is in park and idling.
Old Jul 21, 2011 | 12:53 PM
  #156
CrAnSwIcK's Avatar
the whistle? probably power steering...turn the wheel back and forth while stopped and idling and see if it fluctuates.
Old Jul 24, 2011 | 07:46 PM
  #157
RICKY01's Avatar
I just recently had a transfer case installed on my 2006 evo ix and the car worked great for about a day. The next day I woke up and started to pull the car out of the drive way when I hear a weird ticking sound. The ticking sound comes from under the car on the driver side. But the ticking noise only happens when the car is moving in other words driving. If you drive slow it ticks slow as you accelerate the ticking does too. But if you putt the car in neutral there's no ticking sound you can even rev the car while its in neutral and there's no ticking noise. Does anybody have any ideas?
Old Jul 24, 2011 | 11:23 PM
  #158
keithrybicki's Avatar
My accessory belt squeals like a mother on cold starts (2003 OZ rally). I have changed the belt and the tensioner. Any advice - I have already tried tightening it and loosening it and nothing seems to make a difference.
I am thinking of changing out the tensioner hardware - does anyone know where I can get these items or the part numbers?
Old Dec 6, 2011 | 07:11 PM
  #159
D'sEVOIX's Avatar
I have a rotational whirring noise when making sweeping left hand turns. Not when going around a corner but when making gradual left turns down the road.
any ideas or advice.. sounds like it is right unders the driver's floor board. i can feel it with my feet. Bearing maybe...
Old Dec 17, 2011 | 01:12 AM
  #160
RDSSPIEGEL's Avatar
Exclamation Engine Ticking. Noise
ok so recently my 03 OZ lancer has started making a ticking noise.
I am hoping this is nothing serious the car has 145,000 miles, so I understand things are goin to start failing.
Here is a Video of the issue http://youtu.be/p4__C1WWzNc?hd=1
Please post any ideas or thoughts,
Thanks for the Help.
Old Dec 17, 2011 | 09:10 AM
  #161
CrAnSwIcK's Avatar
valve lash too big, is what it sounds like...pull the cover and measure all your gaps, it sounds like one or two are slapping...how's your oil? last change? and weight of oil?
Old Dec 17, 2011 | 05:24 PM
  #162
RDSSPIEGEL's Avatar
as far as i know the oil is good, every 3k and standard oil wieght 10W40....
Note, About 3-4 years ago, the stupid Valvoline oil change did not properly put back on the drain plug and I ended up with real low levels, where I had the Tickining up the ying yang. mitsubishi said there was no harm done but ever since then the motor was louder(not like it is now, but louder than when i bought it) , could they have been damaged then and finally gave out now?
Old Dec 17, 2011 | 07:37 PM
  #163
03lances's Avatar
+1^^
You have valvetrain noise caused by incorrect lash. You have one of three issues going on
1. One or more of the lash adjusters are dirty
2. One or more have collapsed and need replaced
3. Air has entered one or more of them causing the excessive lash.
Here is something to try if #3 is the case.
Bleeding lash adjuster system
1. Check engine oil. Add or change oil as required.
NOTE: If the engine oil level is low, air is sucked from the oil
screen, causing air to enter the oil passage.
NOTE: If the engine oil level is higher than specification, oil
may be stirred by the crankshaft, causing oil to be mixed
with air creating aerated (foaming) oil.
NOTE: If oil is deteriorated, air is not easily separated from
oil, increasing the quantity of air contained in oil.
NOTE: If air mixed with oil enters the high pressure chamber
inside the lash adjuster from the above causes, air in the
high pressure chamber is compressed excessively while the
valve is being opened, resulting in an abnormal noise when
the valve closes.
This is the same phenomenon as that observed when the
valve clearance has become excessive. The lash adjuster
can resume normal function when air entered the lash
adjuster is removed.
2. Idle the engine for one to three minutes to warm it up
Repeat the operation pattern, shown in left figure, at no load
to check for abnormal noise. (Usually the abnormal noise is
eliminated after repetition of the operation 10 to 30 times. If,
however, no change is observed in the level of abnormal
noise after repeating the operation more than 30 times,
suspect that the abnormal noise is due to some other
factors.)
4. After elimination of abnormal noise, repeat the operation
shown in left figure five more times.
5. Run the engine at idle for one to three minutes to make sure
that the abnormal noise has been eliminated.
AKX00330
OPEN THROTTLE
VALVE GRADUALLY
CLOSE
THROTTLE VALVE
APPROXIMATELY
3,000 r/min
IDLING
OPERATION
ONE CYCLE
15 s 15 s
AIR BLEEDING OPERATION PATTERN
AD
If this does not fix your problem then its either dirty or has failed. In either case the cam will have to be removed and lash adjusters pulled and cleaned and/or replaced.
Old Dec 20, 2011 | 03:06 PM
  #164
rebdull's Avatar
i have a weird hussing noise which has now turned into a full on grinding/metal noise whenever there is load on the front left. seems to be quieter when wet. this happens at 5mph + usually when turning right, but generally when the weight has shift to that corner. everytime i take it in to show someone the noise gets shy. gah !
Old Dec 20, 2011 | 05:01 PM
  #165
03lances's Avatar
My guess is wheel bearing. Though could be a rock in the brake caliper or your dust sheild got bent rubbing on the rotor.
