Eclipse/Talon, no CEL issues,why?
Old Apr 15, 2005 | 01:08 PM
inariv5573's Avatar
I keep reading of stories about how the Evo's CEL is so sensitive. Particularly with high flow cats and test pipes. I am just wondering why the Eclipses and Talons never had that problem. Had a high flower and no problems. People with test pipes never complained about CEL's. Maybe we should try to figure out their secret.
Old Apr 15, 2005 | 01:32 PM
4ce fed's Avatar
I had a test pipe on my Eclipse and it threw a CEL. But I turned it off with DSMLink.
Old Apr 15, 2005 | 11:00 PM
inariv5573's Avatar
My Eclipse failed one inspection, but didn't throw a CEL. The increased emissions were due to leaky valve seals. Wouldn't that still set off the CEL?
Old Apr 15, 2005 | 11:15 PM
2GDSM's Avatar
yeah the test pipe on my eclipse throws a CEL... you must remember whether the car is OBDII or OBDI... I believe the 1995 DSM's were OBDI's. You can fail inspection even without the CEL for the cat. The last O2 sensor is basically used to determine how efficient the cat is, but some things, (like oil) when burned, arent designed to be taken out by the cat, so if you have leaky valve seals, the cat wont do anything to help the situation thus you'll still fail emissions.
Old Apr 15, 2005 | 11:17 PM
2GDSM's Avatar
The DSM guys usually put a resistor into the O2 sensor to get rid of the CEL.
Old Apr 19, 2005 | 05:22 PM
chrisw's Avatar
DSM emissions requirements are not equal to the Evo's requirements.
Old Apr 19, 2005 | 08:43 PM
Mercenary3's Avatar
UHHHHH....different ECU, new emissions requirements, new cat technology, cleaner running engines, new 02 sensors, new emissions algorithms, different exhaust architecture,.....etc etc etc
Old Apr 19, 2005 | 10:44 PM
2GDSM's Avatar
Uhhh 2G's basically instantly threw a CEL as soon as the cat was replaced with a straight pipe just as in the Evo's. The emissions requirements are the same for both cars, the cat technology is simliar, the engines run similiar cleanliness when stock, the O2 sensors are designed to last 100k miles, and they are both OBDII. The DSM guys had several ways to get rid of the CEL.
Old Apr 20, 2005 | 11:50 AM
WHTEVO's Avatar
2g will still throw a code with a test pipe. 1g won't because they don't have the second o2 sensor after the cat like the 2g does.
Rguy
58
Jan 9, 2013 10:13 AM
vincentchua
Jul 21, 2010 05:24 AM
razorlab
40
Mar 10, 2008 11:19 PM
CleverUserName
May 5, 2007 12:45 AM
Trustz
Jul 9, 2003 05:06 PM
