EnglishRacing Evolander Begins
Old Oct 20, 2012 | 11:56 AM
  #76
HHIX's Avatar
any new´s ?
Old Oct 20, 2012 | 11:58 AM
  #77
HHIX's Avatar
and is it correct that evo evo suspension is identical to the outlanders ?
Old Oct 23, 2012 | 05:18 PM
  #78
JohnBradley's Avatar
Evo suspension is not identical to the Outlander. The car went on the dyno but hasnt gone back to the track since the PNW is stuck in its annual 9 month rain cycle now. At 15psi it now makes 221whp and holds it all the way to redline where before it peaked at 4500 and then started a pretty marked drop until 6k where it was down to 140whp.
Currently stock cams and motor but over the winter it will get a LR2.4 and some S1s. Most likely a larger turbo as well as Jeff would like 400whp or so through the auto.
Aaron
Old Oct 30, 2012 | 07:45 PM
  #79
Latest update-
Added an ER testpipe dump and retuned for high boost (finally)-
Next step will be a built motor or cams or both or larger turbo or all 3.
Here is the start to finish of this project so far (still stock motor)-
Old Nov 24, 2012 | 10:15 AM
  #80
chamelieon's Avatar
Hey Im in the middle of this exact project for a customer, except we converted the car to 5spd with full evo transfer case and tranny. built 2.4 pistons and rods with evo8 head. everything is done and ready to start. so my 2 questions are:
1- what is the ratio of the rear end in the outlander compared to the evo transfer case?
2- I still have the outlander ecu in the car and you had said physical modification is needed to get it to work, but I also have an evo8 ecu to use as well and since the car is no longer auto im guessing that is the better route. have any suggestions?
Old Nov 24, 2012 | 12:16 PM
  #81
1- 3.312 instead of the 3.307 of the Evo....but close enough to work without issues.
2- Just flash it as an Evo 8 if you have done the 5 speed swap.
aaron
Old Nov 25, 2012 | 01:17 PM
  #82
chamelieon's Avatar
aaron
Thanks for the quick reply bro. Outlander is an 2003 so I'm hoping to unplug the outlander ecu and plug in the evo8 ecu. I'm still using the outlander harness and wiring. But the the taxtrix cable yellow plug isn't under the evo lander dash so I'm guessing its a certain wire that goes right to the ecu to enable the reflashing.. know the pin # ?
Old Nov 26, 2012 | 01:52 PM
  #83
The ECU isnt a swappable item but the ROM is, the wire is the same color as the Evo. We just spliced into that rather than run it all the way to the ECU.
Old Dec 25, 2012 | 01:50 PM
  #84
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
SUB'D to see where this goes. i just got to see my first EVOlander at UCS performance and they are so subtle and clean. i love the idea and the fact that people like you guys are building them! keep up the good work!
Old Dec 31, 2012 | 10:21 AM
  #85
_AH_'s Avatar
Hello from Finland!
Had to register for this. Have been reading forums for quite and now have to write.
Happy to see people modifying Outlanders as I think these are cool cars.
I have litte similar project going but the starting point is little easier as in engine comparement already have this with 5spd manual.
Didn't you have 4g63t engine as option at all in US market?
Mitsubishi did Outlander as a turbo from factory and I'm not talking about Airtrek here.
My goals for now are +300hp. Finnish traffic laws are quite strict in modifying cars this "new" so my mods have to be done subtly and factory-like so it won't fail annual inspection.
If interested you can see more pic's from my Outlander from here.
Old Jan 1, 2013 | 09:33 PM
  #86
chamelieon's Avatar
Huge thanks to Aaron for the email help back and forth!
this must be the most fun project i have done to date!
very very simple build with great results!
will be making a thread shortly with details.
Old Jan 15, 2013 | 07:50 PM
  #87
Dylphill85's Avatar
Veteran: Marine Corps
Any updates on this?
Old Jan 17, 2013 | 09:13 AM
  #88
Thanks for the link.
The US market Outlanders werent turbocharged until VERY recently with the new body style change. I prefer the 4G64 for the most part, especially when its a street car such as this.
The plan for Jeff's car at this point is a built motor, cams, turbo kit.
Aaron
Originally Posted by _AH_
Hello from Finland!
Old Jan 19, 2013 | 09:58 AM
  #89
EvoG8r's Avatar
This is on my list as my eventual daily. just gotta find a cheap awd outlander.
Old Jan 19, 2013 | 01:01 PM
  #90
It's fun sleeper status for sure. Even if the auto doesnt work out, one of these with a 5 speed is stealthy and only 150-200 lbs heavier than an Evo.
