Focus RS
Old Apr 7, 2015 | 04:00 PM
  #556
Robevo RS's Avatar
Originally Posted by ambystom01
The Evo X should be called a first gen Evo, since it's the first to use the 4B11T?
for sure, and the chassis.
and it has 14 years + racing developments and engineering behind as the new RS will have.
Old Apr 7, 2015 | 04:01 PM
  #557
RazorLab's Avatar
Can we change the title of this thread to be: "Robevo stares in the mirror and argues to himself about the same thing over and over again"?
"Insanity: doing the same thing over and over again and expecting different results." - Albert Einstein
  #558
whtrice's Avatar
Veteran: Air Force
Originally Posted by Robevo RS
so RS means?
Robevo's last name?
Old Apr 7, 2015 | 04:03 PM
  #559
Robevo RS's Avatar
Originally Posted by whtrice
Robevo's last name?
sure lol
Old Apr 7, 2015 | 04:05 PM
  #560
Robevo RS's Avatar
i am patient as a dog trainer, hoping you and your triumvirate might learning something .
see what happens, you guys got a bone throw in.
ps thank you to quoting Einstein . def elevated your post.
Old Apr 7, 2015 | 04:29 PM
  #561
hotrod2448's Avatar
yep. and you loving it.
to the other guy there is no evo XI. and even if it would be, i would still get the RS instead. even if that is a first gen.
Right so get an Evo XI RS? Is that the real JDM?
Old Apr 7, 2015 | 04:38 PM
  #562
Robevo RS's Avatar
Ford RS – 47 years of performance and innovation:
Old Apr 7, 2015 | 04:59 PM
  #563
whtrice's Avatar
Veteran: Air Force
Ford RS – 47 years of performance and innovation: Ford RS – 47 years of performance and innovation - YouTube
Dammit throw back Tuesday. Seeing those Capri's racing around makes me realize how old I am. Thanks Rob
Old Apr 7, 2015 | 06:46 PM
  #564
ninjacoco's Avatar
Balls of Steel
so RS means?
Camero*!
https://www.youtube.com/watch?v=GKruim6iatA#t=12
*traditional craigslist spelling
Old Apr 7, 2015 | 06:48 PM
  #565
Raptord's Avatar
http://www.topgear.com/uk/photos/for...ine-2015-04-07
-"At least 320 hp"
Other notable tidbits:
"This isn't just a standard AWD, it's Ford Performance AWD. We're using a system we believe no one else is." So it's not the same as the basic get-you-out-of-the mud Kuga set-up. Crucially, it mostly doesn't control the car's trajectory using the brakes. "We can control the torque front to back but also side to side. With more power to the outer rear wheel dynamically, you can drive the car through that corner and eliminate understeer. The capability is unbelievable. It's going to shock you guys when you get behind the wheel."
(emphasis mine)
There's no rear diff at all. Instead, either side of the crownwheel and pinion are clutch packs. Each of those packs, one per side, is independently controlled by the electronics, so that the torque to each rear wheel is determined by the amount of slip in its clutches.
Old Apr 8, 2015 | 07:26 AM
  #566
nemsin's Avatar
Hurray for not relying on brake based torque vectoring.
Old Apr 8, 2015 | 09:08 AM
  #567
Raptord's Avatar
The way things were worded, it does sound like it uses some in the front.
Old Apr 8, 2015 | 09:14 AM
  #568
RazorLab's Avatar
I think this was already posted in this thread but I will post it again as a bunch of good info has already been buried.
Old Apr 8, 2015 | 09:34 AM
  #569
nemsin's Avatar
"To optimize handling and stability, the car’s brake-based Torque Vectoring Control is tuned to work in parallel with the torque vectoring AWD system."
I guess owners just have to hope it doesn't eat pads/rotors at the track.
Old Apr 8, 2015 | 09:46 AM
  #570
RazorLab's Avatar
I don't notice any abnormal pad wear on my Fiesta ST on track with all the nannies off. If you keep them on, the brakes go up in smoke, literally. The Torque Vectoring seems to work okay with the brakes, it's when you have the nannies on and it has to act as a LSD too is when the brakes get reaaaalllly hot.
Who tracks with nannies anyway.
