Mk V Supra - My Evo's Replacement?
Old Jan 25, 2022 | 11:00 AM
  #946
lv05evo's Avatar
Originally Posted by razorlab
I am honestly amazed he is still in business. If he wasn't well-off, he probably wouldn't be.
Best definition of him is grifter. Does he just move on to other platforms once its found out he doesn't know what he is doing? I never followed up on the BMW 335I he moved on to after Evos which I think was still Vishnu.
Old Jan 25, 2022 | 12:07 PM
  #947
RazorLab's Avatar
He was big in the BRZ/FRS scene for a bit. Then some Miata stuff. Now I think he is trying to find the next group of suckers.
Old Jan 25, 2022 | 12:12 PM
  #948
EVO8LTW's Avatar
Originally Posted by Dallas J
Haha, that clown has no credit in the Evo community.
Anyone else remember the fierce battles on this board arguing whether the Vishnu Xede was superior to a reflash? Of course, back then, a reflash was often a Dynoflash quickie with a big block of 8s in the middle of the timing table.
Old Jan 25, 2022 | 12:15 PM
  #949
RazorLab's Avatar
I do indeed.
Old Jan 25, 2022 | 12:27 PM
  #950
SoSoEVO's Avatar
Hi guys! do I need a new a90 supra to post in this thread LOL?!?! Thanks for ordering me parts Sean!
Old Jan 25, 2022 | 12:53 PM
  #951
lv05evo's Avatar
I won't be getting one for at least two years. I decided to go back to school.
Old Jan 25, 2022 | 12:59 PM
  #952
WarmMilk's Avatar
All fully locked (post June 20, 2021 ECU date) have to go to Russia for unlocks. Currently. Every single one. Shiv doesn't have magic fairy dust. I believe the 2021 in the article was pre full lock down. Or he sent the ECU to russia, because that is what EVERYONE currently has to do.
As far as the article. It's Shiv. He hasn't done anything differently than anyone else. Also ain't making 500hp if it's only trapping 119. Guy is a trust fund doof. Who cares.
why do they have to go to Russia? can't whoever does them in Russia license the process to someone here? or is everyone in the US scared of getting a 6 figure fine from the EPA?
Old Jan 25, 2022 | 01:03 PM
  #953
RazorLab's Avatar
FEMTO is the company, and they are holding the secret close to heart for now. That way they make the money.
Doesn't matter to me, I have a 2020.
Old Jan 25, 2022 | 01:43 PM
  #954
Lumpy Sticks's Avatar
5 Year Member
Nah we will let you slide since you are dumping $$$ in your Evo. And no problem. I got some special Evo parts for you too once all your other parts show up. I keep finding stuff in my garage that I wont have any use for haha.
Old Jan 25, 2022 | 01:45 PM
  #955
5 Year Member
I am waiting this one out until prices are actually decent. Car has plenty of power for now. The JB4, once tuned right, gave it a nice bump in power and should hopefully keep things safe.
Old Jan 25, 2022 | 01:47 PM
  #956
RazorLab's Avatar
Yea, It will go way down and I am 100% sure it will be available in the states. Remember, it's not just the Supras that are locked (small market) but all the BMW's in the same time period (large market)
Old Jan 25, 2022 | 02:18 PM
  #957
kaj's Avatar
kaj
Kinda offish topic since I didn't end up with a Supra: I may or may not have driven the Moostang around an onramp, in the middle of the night, at about 104mph. The car may or may not have been DEAD NUTS flat with absolutely zero drama or acting like it was having any difficulty. The Evo was a lot more active and affected by the expansion joints and had to be actively driven around the same turn. I am really, really, really surprised. I had no idea as I've never driven anything newer in the same way. I felt like I could have done the turn 50mph faster, and this was on Pilot 4s that were a bit overly wide in the back. WOW. I have a track day on Feb 6 at the local Time Attack course, so I can get an apples to apples comparison on lap times. I'll be going with only an alignment via camber plates on the GY SC3R 305 squared tires.
At first I was like "meh" about the car, but now I'm getting pretty excited. This thing may be an absolute blast on course. I'm told I should be able to do a 1'53" without really trying. I think that is a bit ambitious, seeing how the Evo did a 1'56". We'll see. I haven't been this stoked for a track day in a long, long time.
Weird bit of info: I'm thinking the car pulls power in 1st gear. Without the traction control kicking in, the car seems to not accelerate very fast, but when I go into 2nd, it all of a sudden GOES. I know one of my other car is programmed to do the same, so I'm wondering...
Old Jan 25, 2022 | 02:53 PM
  #958
Dallas J's Avatar
Veteran: Army
One of the crap things about some aftermarket Evo parts is the induced stiction. Things like rear lower control arms with urethane bushings or front lower control arm offset bushings. Those really only serve to make the handling sketchy.
New cars seem to do a lot of work in using the flex in bushings as part of the chassis spring rate and when we switch those out for urethane we lose that flex but gain stiction. I suspect if you pulled rubber bushings out of the mustang it might feel sharper but also twitchier.
And theres also something to be said about just being softer overall. Mustang is wider and lower CG which certainly helps. And new strut cars also tie sway bars into the strut so as you steer that bar is preloading (because of caster) to also reduce roll. Effectively creating more load as the wheel is turned tighter.
Old Jan 25, 2022 | 04:02 PM
  #959
kaj's Avatar
kaj
I was in comfort mode, so the car was probably more compliant that any other mode. Seeing how the Evo is always in "track mode", that could have something to do with it. Also, the Mustang has fancy magnetic shocks, so there's that.
There is definitely something to be said for modern tech.
I've had some purists give me a hard time for "bought not built". But I look at it like this:
I've already built a hand full of cars. I deserve a break. The Mustang has everything I'd do to it anyway: Brembos, Recaros, lightweight/big wheels that I could never get on my own, big rubber, decent aero, 500+hp, decent exhaust, and I don't have to mod the engine. All I've done is pay for the mods up front and had the Ford technicians do the install for me. With a warranty. It all ends up the same, anyway. The fact that it may be faster than something someone else built isn't my fault. With the Evo, I kept hearing a guy complain about always being beat by a "500hp Evo that drives itself", so peeps are always gonna whine when you are faster.
TLDR: I'm gonna enjoy the crap out of this car for the next 12mos.
As for low/wide: You should see it next to the Evo. The mustang is as wide as a Viper but lower than the Evo. Having them parked next to each other was a really interesting thing to see.
Old Jan 25, 2022 | 04:26 PM
  #960
Crzykdd's Avatar
Yeah he is definitely well off, hes in that FB group I'm in and constant posts with a Ferrari, Porsche, Dodge Hellcat, or M5 that he is "playing" around with. Dude constantly switching platform, its like whatever. What is that saying? "master of all and master of none...."
Of course on that FB group he just gets pandered too, and he only posts to stroke his on ego (but thats a lot of people there...to be fair).
