Sponsored by:
Sponsored by: CARiD
Removing Mitsubishi Badge On Front Bumper Grill
Old Apr 25, 2010 | 05:57 PM
TrackDays's Avatar
I am debating on removing the mitubishi badge on the front bumper but wanted to know if anyone here has done it and could give me some advice on a how to. Since its basically part of the bumper it looks like you would have to actually hack saw it off which might make it look bad unless your careful.
The silver part of the badge somehow seperated and fell off over the winter. Its now black with a hole in it where the badge must have been bonded to. It doesnt look the best
Old Apr 25, 2010 | 05:58 PM
aftershock141's Avatar
You could just fill it in with bondo and spray paint it flat black.
Old Apr 25, 2010 | 06:02 PM
BAMFevo's Avatar
Does this help?
https://www.evolutionm.net/forums/ev...er-emblem.html
Old Apr 25, 2010 | 06:11 PM
TrackDays's Avatar
^ not really. Wanting to know from anyone who has actually hack sawed it off, if it turned out messy or not. Maybe some pictures, and what they may have done to clean it up. sand paper?
Old Apr 26, 2010 | 05:45 AM
82firebird's Avatar
If you were going to try this the one thing you would have to think about is where the emblem meets the grille. Depending on whether the joint between the and emblem grille is solid, you may have some filling to do. You can't (you shouldn't) use bondo or fiberglass on plastic, so you'll have to use either an ABS filler or make your own (basically melt plastic to bond with the grille). If you've never attempted any type of body work it might be best to find a friend who has.
I'd recommend finding a use grille before hacking up the original!
Old Apr 26, 2010 | 06:43 AM
shizblam's Avatar
At least one of the guys on the forums used a dremel and cut the bumper flush... He then plastidipped the entire black part of the bumper.... Looked pretty good. I'm just scared to do it.
I'd get another Mitsu emblem if I were u ;P
Old Apr 26, 2010 | 09:12 AM
TrackDays's Avatar
Thanks guys im scared to do it. Ill just leave it haha
Old Apr 26, 2010 | 09:28 AM
xPRimNT's Avatar
Talk to DrasticK. He's local to you and did it. It definitely involved some work
Old Apr 26, 2010 | 10:15 AM
ohitisethan's Avatar
just leave it for now until more people do it. i know some people spray paint them.
Old Apr 26, 2010 | 11:29 AM
CC16's Avatar
I taped mine off and hit it with a scotch-brite pad to scuff it up. Then just spray-canned it black. Looks quite good actually.
Old Apr 26, 2010 | 11:51 AM
TrackDays's Avatar
mine is black... just because its missing the actual badge since it fell off. It looks ok except for the fact that there is a big chip in it maybe from where the badge attached before or a rock chip.. im not sure. Maybe the reason if fell off was from a rock hitting it and shattered the badge and left a chip underneath. Might have to go back to the dealership and get them to get me a new one.
Old Apr 26, 2010 | 12:36 PM
newcomer81's Avatar
^ this
you have to remove the whole bumper and cut both the top and bottom to remove it. its an easy process. bondo and sandpaper it smooth then hit it with some flat black.
QwikEVO
Sep 6, 2015 02:18 PM
axiomstyles
Evo X How Tos / Installations
Feb 16, 2012 12:58 PM
lancerzdropped
Dec 27, 2007 03:59 PM
fastassfourdoor
21
Aug 12, 2007 08:56 PM
I REP 838
Mar 26, 2004 12:37 PM
