Street Modified update
Old Aug 7, 2005 | 10:09 PM
  #226
markdaddio's Avatar
Just got back from Toledo Pro. Interesting day today was. Tunnell ended up winning by .5 seconds. My car was much better today. 60 foot times were in the low 1.6's. Unfortunately I was getting such a great bite with the increased launch rpms, I redlighted two of my four runs today. ( The two fastest ones ) Fortunately the times I ran on those two runs would have given me the win by about one second. I was living with a best time on the right course of a 32.2, and ran a redlight 30.8, and followed it up with a coned 31.5, either of which would have been enough. I also managed to redlight a 31.3 on the left course. The left redlight was only by .004 seconds, and the right redlight was by .018. The car is awesome in transition, but needs a little work getting the power down coming off of full load corners on throttle. I am thinking that it is possible that my rear diff is toast. Much work to do before nationals to get more weight out, and try to get the power down a bit better. It is really gonna be an awesome competition in SM at the nationals this year.
Mark
Old Aug 8, 2005 | 07:08 AM
  #227
lacartus's Avatar
Thumbs up If you missed how to disable the 5k launch limiter...
Originally Posted by markdaddio
I really need to disable the 5,000 rpm launch limiter for tomorrow. I just need to figure out how to do that.
Mark
This thread has a description of how to disable the 5k rpm launch limiter, with pictures.
https://www.evolutionm.net/forums/sh...d.php?t=108697
Nice runs. Sounds like nationals is going to be a hoot.
Old Aug 8, 2005 | 08:32 AM
  #228
Silencer's Avatar
Originally Posted by EVOlutionary
Silencer (Dave) -
Where are you from in Michigan? Do you run the DRSCCA or SVR AX races?
I know John and Andy. I have definitely learned alot over the past year by watching both of them and picking their brains. I am getting ready to step up to the A3S04. I have the tire but I have to wait for 5Zigen to get some more wheels in stock for me. So far this year I have just been running the Azenis RT-615. Andy (from Showcase) drove my car at an event and said they were about the best street tires he had experienced. I've done OK in SM in the regional events, only lost once - to a Honda in the rain! I was totally shocked!
Anyway, I am looking forward to running the whole CenDiv series and as many ProSolos as I can get to next year, as well as Nationals. Can't wait to go up against some great national level competition to see how far off the pace I am. I've only been running AX for a year now, since I bought the EVO from Andy's dealershp and he talked me into coming to a race. I am absolutely hooked!
EVOlutionary
I live in Holland and usually attend some of the WMR, SBR, Furrin Group, and Cendiv events. Except this year I've had to wait for parts most of the season, plus a newborn daughter so time has been limited. Although I play in the local SM class, my car is set-up for STU. Still debating attending Nationals. Might not be a class if attendance stays at 12. Hate to get bumped into BSP again, unless it rains.
Eric, missed you at the Toledo Pro. I was looking forward to see your car since the transformation from ESP. Are you still going to the Cendiv Championship this weekend in Peru?
It was interesting watching Tunnell and Daddio run together. Tunnell was faster in the corners, Daddio through the slaloms. Each had the lead at different points on the course.
Dave
Old Aug 8, 2005 | 08:37 AM
  #229
93esp's Avatar
I will not be at the Cendiv Championship.... apparently I broke some transmission parts as well in Oscoda....
Eric
Old Aug 8, 2005 | 04:17 PM
  #230
Navid's Avatar
Originally Posted by jbrennen
I wouldn't necessarily trust the accuracy of 60' times from a ProSolo.
They are close enough. I did a couple of 1.6 60 foot times at the Atwater Pro, but I didn't trust the Pro measurements either. Last Wednesday, I took the ESP Evo to the Infineon raceway for the Import drags (my first drag race ever). I did a few 1.6 times with the lowest being 1.663. However, I need to launch my car at 7K. Best 1/4 mile time: 12.333, best trap speed: 110MPH.
I was on V710 Kumhos.
--Navid
Old Aug 8, 2005 | 04:31 PM
  #231
93esp's Avatar
Those are some pretty good times for an "ESP" car....
I can say the Evo driveline isn't designed to turn high 1.4 60' times reliably... I have a box full of parts to prove it... Probably launching at 5000 rpm and 30 pounds of boost wasn't such a good idea although it was pretty fun.
Eric
Old Aug 16, 2005 | 03:19 PM
  #232
97itr153's Avatar
Edit
Old Aug 16, 2005 | 03:25 PM
  #233
97itr153's Avatar
Yes to all of the above. In addition
- with the staggered tire setup, the front and rear build heat more evenly, creating a more consistant balance from beginning of run to the end.
- The mid corner off understeer that we are trying to avoid, is much easier to avoid with a smaller rear tire. (since the inside rear isn't really doing much if anything at that point)
- running a smaller rear tire allows me to run a more transition friendly alignment.
Hope that sheds some light on my thinking.
Mark
Mark, What camber and toe setting are you running?
I have my A-Stock 2005 Evo RS set to Zero Toe all around and camber maxed out at -2.0 up front and -1.8 in the rear. Any advice?
Also I am thinking of getting V710s in a 245/40. Do you think that is the right tire/size combo or might my car benefit from a staggered setup like you had experimented with? Currently I just use a little bit of trailing throttle / trail braking to get rotation before the exit.
Old Aug 16, 2005 | 07:27 PM
  #234
markdaddio's Avatar
Currently I am running -2.4 camber front, and toe out 1/16", and rear I am running -1.5 camber, and toed in 1/32". As for the staggered setup, I believe that the acd on the 05's defeat the desired effect. I am currently running 285/30/18 Hoosiers all the way around, and it seems to be working quite well.Mark
Old Aug 16, 2005 | 11:10 PM
  #235
RazorLab's Avatar
--Navid
How the heck you trapping 110mph with stock boost control?
Old Aug 17, 2005 | 03:21 AM
  #236
EVO8LTW's Avatar
That's not surprising at all with a turboback, good AFR and advanced timing.
Old Aug 17, 2005 | 10:42 AM
  #237
RazorLab's Avatar
Must be with a lightened car and 100 octane. No way a full weight car on 91 is doing 110 mph traps with his mods.
Old Aug 17, 2005 | 02:02 PM
  #238
ratt_finkel's Avatar
Perfectly legal for ESP competition.
Old Aug 17, 2005 | 02:06 PM
  #239
RazorLab's Avatar
I wasn't saying it isn't legal.
Old Aug 17, 2005 | 02:10 PM
  #240
evo_il8's Avatar
u got any pics of ur car?/
