Comprehensive Evo STU prep thread?
Old Mar 26, 2007 | 09:38 AM
  #286
kekek's Avatar
Originally Posted by madmax199
I agree with Dave Mack and CRBD that the temp should be a couple more degrees hotter from Inside/middle/outside because not only because of the neg camber that causes the inside to consitently see higher loads but also because the outer edge gets to see more air(from the side) and cools down better than the inside . The only thing I would add is that autocross r-compound seems to build heat from outside/in due to the amount of time spent cornering as opposed to road race tires that gets their heat from inside out (friction caused by load of rotating tires) and my point is that measuring temp on the tires is better accomplished (for autocross) using laser reading that reads outside temp then a probe that goes inside of the tire. Again as stated by the other guys you ned to beat the living out of the tire and take the reading as soon as possible because fast cooling autocross tires will negate your effort if not done in matters of seconds.
I disagree with you about the IR vs probe. Autox tires see a good bit of heat soak after very few runs. The IR ones will also have inconsistencies based on distance from the target as well as weather conditions (cold temp, breezy, etc). Thats why they have a little chart on them telling you how the temp is avg'd over an area based on distance from the object being measured.
Old Mar 26, 2007 | 10:43 AM
  #287
madmax199's Avatar
You are right john about possible inconsistencies of IR due to outside temp and distance of each reading. However, if measurement is taken on one tire, 3 spots in matter of seconds the temp variation should be negligeable. Now the next issue is to keep distance constant, I have my IR mounted on a homemade handle that keeps distance the same without interfering with reading. Longacre recently came out with a neat inexpensive pyro that combines both IR and and probe; I think it would be a valuable tool for as you can do both core and shell mesurements and compare.
Old Mar 26, 2007 | 11:27 AM
  #288
McCall's Avatar
Originally Posted by CBRD
the only way to truly check the temps is to beat the living crap out of it, and test as soon as possible. The tricky part is, if you are setting up for the most "time affecting" portion of a circuit, and it's on the farthest side of the track from the pits, you tend to lose the temps generated on that portion... which is where your temps may not look "even" accross the tread surface, but it may be working effectively in that section.
This is true for a road course car but for autox I have always used a skid pad to determine the amount of camber you need to run. You have someone standing by inside the circle with the pyrometer and then you can get temps pretty instantly. Circumference the circle one side at a time with a tight circle and take temps and then again with a wider arc and take temps. Using the hotter-inside-out theory, you should see consistant temps between both arcs. That then shows you that no matter the tightness of a turn on course, you should have consistant handling.
Of course I am by no means a tire/suspension tuner expert. Just consider me a hack
Old Mar 26, 2007 | 12:17 PM
  #289
Silencer's Avatar
if you are running the proper amount of camber you will always see a tiny bit more heat on the inside edge because of the tire rolling when it is unladen not being in a corner....
cb
This statement is probably correct when referencing road course data, but this is Autocross (ST) where the tire spends most of the time in transition and steady state cornering and little time on straights. 8-10 degrees hotter on the inner side usually indicates your camber setting (dynamic) or tire pressure is in need of attention.
Camber limited suspensions or heavy inside tire spinning on corner exit can contribute to hotter inner tire temps. Also, running a good amount of front toe at high speed, low transition AutoX course's will create a similar effect.
However, I do agree that gathering tire temperature data immediately following a run is critical.
I also agree with kekek with IR vs. probe pyrometer.
Of course, IMHO.
Dave
Old Mar 26, 2007 | 12:19 PM
  #290
Silencer's Avatar
Jason beat me too it.
Old Mar 26, 2007 | 05:07 PM
  #291
CBRD's Avatar
i disagree, but I obviously have my routines from our past experience...
you have to do what works for you guys... and it appears its working for many of you!!
cb
Old Mar 27, 2007 | 07:13 AM
  #292
russjnco's Avatar
In relation to IR vs. Probe, a friend and I did a comparison last year to see what the difference would be. He had the IR and I had the probe. We took temps right after one of my runs and the IR would consistently read about 5 degrees cooler than what the core temp would be. The IR would also show different readings on the sunny vs. shade side of the car. Can you get some use out of an IR, yes, but there's a lot of variables there that you would have to adjust for
Old Mar 27, 2007 | 06:54 PM
  #293
wrcwannabe's Avatar
I agree with the sunny/shade side. ive noticed that myself in the blazing Georgia sun. Remember you have to get the temps immediately after the run but when was the last time you did not spend 2 minutes driving slowly back to the grid. I know the Atlanta region cues you to stay inline and keep moving until you get back to your spot in grid too. So no stopping just after the course exit either. i d add about 10 degrees if it takes 2-3 minutes to park it and start testing.
Milburn
Old Mar 28, 2007 | 01:42 PM
  #294
SS RX7 r2's Avatar
I just wanted to congratulate Jason Uyeda on a convincing STU class win at the very fast El Toro ProSolo. He has dialed in his SE IX and driving style in very short order and will only get quicker.
I think it was his trick "composite" wing that did it!
Rick
Old Mar 28, 2007 | 07:07 PM
  #295
Slowride's Avatar
Originally Posted by Dave Mac
Okay guys. I just got back from CBRD Racing Development and have some nice results from the exhaust mods and STU LEGAL tune. ...
You guys with tunes...are you flashing with Ecuflash, using a piggyback, or what?
Old Mar 28, 2007 | 07:15 PM
  #296
Dave Mac's Avatar
ECUflash.
find someone good of they'll f-up your car.
If you are willing to drive to PA I would whole heartedly recommend CBRD. Chad did a fantastic job on my car. Ermm...nevermind, I don't want another fast Evo around.
Old Mar 28, 2007 | 07:23 PM
  #297
CBRD's Avatar
we could do STU email flashes!
dave's map was conservative and knock free!
cb
Old Mar 28, 2007 | 08:45 PM
  #298
Solo Evo's Avatar
What would pricing be? Do you have a similar map for the VIII's (03)? Just curious for later reference as I won't be flashing until the summer once I have all the STU "bolt-ons."
Devin
Old Mar 28, 2007 | 10:24 PM
  #299
CBRD's Avatar
Devin
mostly ix stuff right now,
ill work on getting an 8 with comparable mods for an stu legal dealio
cb
Old Mar 29, 2007 | 03:45 PM
  #300
NotMyEVO's Avatar
ECUflash.
What is this suppose to mean?
By the way, good job on your runs!
