Comprehensive Evo STU prep thread?
It's likely that a number of cases of rear inside wheel lift is not just an issue of roll, but an issue of insufficient rear droop travel and/or too much rebound damping.
It's my opinion that with the right roll stiffness and sufficient rear droop travel that you can reduce rear inside wheel lift to an inconsequential level on an STU Evo.
Can you please PM me a price quote with current delivery times for your coilovers. I sent an inquiry on your site but have not recieved a reply. Please include whether or not they come with upper camber plates and pillowball mounts.
Thanks,
John
Steve,
I agree 100%. Both the STi and the Evo really benefit from increased droop travel in the rear. I feel that's why a lot of coilovers (including your's) uses helper springs to utilize full droop and allow the main spring to keep tension.
I know not all STU guys use coilovers with helper springs, so in others' opinions, can one be competitive with the typical non-helper spring JDM type coilovers that rely solely on roll stiffness?
(EDIT: email sent...)
Chris, I'm stoked for you. You won't be dissapointed.
Just a note too guys. The white car is 2-0 against Mr. Burkhart and I drove mom's black car to a two tenths win against him as well today. He is beatable believe it or not.
... Jake you have improved tremendously as a driver.
Why the focus on droop travel? does it matter where you wheel is at if there is no load on it?
Derek and I were talking today, looks like we are going to try and get the car out of the barn this week, WOOOO HOOOOOO! There are some parts to get on it and probably some more tuning by Chad to get it ready.
The rear droop travel issue has more to do with getting power down early than with added traction. The extra travel will just make sure the tire is on the ground early enough (with some load) so that sufficient power can be put down without wheelspin.
Do you think an upgraded rear diff would be a better solution?
edit: obviously not a better solution for STU. But maybe in general?
