Comprehensive Evo STU prep thread?
Old Jun 13, 2007 | 06:15 AM
  #526
whitet777's Avatar
^^^I think it's the new harness Chris ^^^
Old Jun 13, 2007 | 08:55 AM
  #527
Silencer's Avatar
No, no, it's the new Time Attack Volks.
Dave
Old Jun 13, 2007 | 01:58 PM
  #528
madmax199's Avatar
Originally Posted by kekek
I didn't like the bumpsteer kit. Pulled it after 2 events and made some more drastic changes to get this pig to turn.
John, what did it do that made you revert back? How did get the pig to finally rotate the way you wanted without it? BTW great driving last week-end .
Old Jun 13, 2007 | 04:04 PM
  #529
kekek's Avatar
The car was too stable and pushy. It wouldn't turn for me. I swapped some springs and changed the alignment a bit, now it suits my driving style much better. I like lots of lift-throttle rotation (I drive with the gas pedal big time, no LFB for me).
Old Jun 13, 2007 | 04:31 PM
  #530
STUSteveEVO's Avatar
stupid question here....
does anyone plan on buying the evo x and campaigning it in STU in 2008?
Old Jun 14, 2007 | 05:27 AM
  #531
Silencer's Avatar
Yes, only if it is offered with a M/T initially.
Old Jun 15, 2007 | 09:21 AM
  #532
evo8dad's Avatar
Originally Posted by Dave Mac
37front/32-34rear. Used tire temp needle guage to find best range for me.
Those 40-psi pressures just don't make sense to me, they are WAY over the
optimal loading range of the tire. I can understand that pressure for stock class but not when you've got good dampers on......
I was concerned about the high tire pressures but, I am gathering the info from a pyrometer. Unless I am mistaken, shouldn't the inside temperatures be 10 to 15 degrees hotter than the outer temperature? I have used this to determine tire pressures.
Maybe I am just doing something wrong but, per a Longacre pyrometer those higher pressures are what is need to get the 10 to 15 degree difference. I am by no means an expert at this, as I am only in my 2nd full season, 3rd season overall.
The other thing I should mention is that I am currently running Robispec'd KW Variant 3 Club Sports. I wanted to get Zzyzx's setup but they were not ready last year when I was in the market.
Old Jun 15, 2007 | 06:30 PM
  #533
Dave Mac's Avatar
Wait a minute, IIRC Warminster is concrete right? If so then the 40psi makes sense then.
Old Jun 16, 2007 | 09:06 PM
  #534
evo8dad's Avatar
Yeah it is, I forgot about that but, at Boeing I'm still running high temps, however, that could be due to such a small tight course. I've been thinking of maybe uping my spring rates some. Now I'm running 9k F 8k R.
Old Jun 18, 2007 | 04:00 AM
  #535
rio-evo's Avatar
New to STU
Are MBC allowed?
Are After market cams allowed?
Thanks
Old Jun 18, 2007 | 05:01 AM
  #536
Dave Mac's Avatar
Originally Posted by rio-evo
New to STU
Are MBC allowed?
Thanks
No.
No.
That would put you in BSP or SM.
Old Jun 18, 2007 | 06:18 AM
  #537
EVO8LTW's Avatar
New to STU
Are MBC allowed?
Thanks
Cams are a no-no in STU and BSP, though in BSP you can play with cam timing (i.e., cam gears) and add a MBC.
Old Jun 18, 2007 | 07:49 AM
  #538
rio-evo's Avatar
What are some of the most optimal ways to squeeze power and performance out of these cars and stay STU legal?
Old Jun 18, 2007 | 08:02 AM
  #539
Dave Mac's Avatar
Go back and read my #1 post in this thread. It's all there.
Cliff's notes:
3" turbo-back exhaust without 90degree bends (Perrin, Buscher)
Ported stock exhaust manifold (PPI)
high flow cataylitic converter (Perrin, Richard Jung custom made, APS)
02 housing (ebay)
a dyno tune from a reputable vendor (CBRD, CBRD, CBRD, Jester, Sean Ivey, Buscher, CBRD or AMS) No boost control at all, just timing, air-fuel, MIVEC tuning.
See my signature for the best of the best peeps to do business with.
Old Jun 18, 2007 | 08:11 AM
  #540
rio-evo's Avatar
Cliff's notes:
02 housing (ebay)
Does the AMS exhaust qualify?
I have been getting mixed messages about the O2 housing and expected performance numbers.
What about an air intake? Does that make sense?
