The Ultimate Track OIL Temp / Pressure / Starvation Thread!
Subscribe
Jun 4, 2013 | 08:12 AM
  #76
When you go to sticky tires typically, or if you have the engine apart/pan off it's one of those "while you're in there" mods.
Reply 0
Aug 7, 2013 | 10:20 AM
  #77
Quote: I've been monitoring and data logging pretty much every parameter on my car all year with my T/A car. If you guys who actually track your car saw what oil pressures your motor is seeing, you would be scarred for it.
I used to run the ams/moroso oil pan with an accusump. i've tried pretty much every race oil on the market. Different weight oils did effect the oil pressure. After changing a few things with this setup, i was able to raise the lowest pressure i used to see(8psi) to 16psi.
At multiple tracks, I've logged oil pressures in the single digits multiple times within 1 lap. After changing a few things with this setup, i was able to raise the lowest pressure i used to see(8psi) to 16psi. It happens more often when hitting 1.5 to 1.6 g's or above. I do run the stickiest tires available, Hankook z214 C91's.
tc17 hasn't been on evom for over a year, so I doubt he'll respond, but can anyone else who's carefully logged oil pressure on the track share what weight oil worked best for maintaining oil pressure through longer, high-G right-hand turns?
Reply 0
Aug 7, 2013 | 10:40 AM
  #78
Theres a lot of information and different views on keeping oil pressure in this thread. Is their a definitive solution path figured out yet? Something that doesn't require a full drysump if we only care about HPDE and autox.
So far it seems that the baffled pans are marginal in help, kiggly HLA helps a bit, and heavier oil?
Reply 0
Aug 7, 2013 | 10:50 AM
  #79
So, how to the race teams handle this? CBRD? He road races evos, what does he run?
That's where I'd start, personally.
I'm a casual track driver, so I'm going to try the HLA + Baffled pan now that I'm ready for r-comps.
Reply 0
Aug 7, 2013 | 10:51 AM
  #80
Quote: Theres a lot of information and different views on keeping oil pressure in this thread. Is their a definitive solution path figured out yet? Something that doesn't require a full drysump if we only care about HPDE and autox.
What you can do? - Wetsump pan, heavier oil, hla, accusump, don't run really sticky tires, and avoid tracks with high speed/sustained right hand sweepers.
Soon there will be a solution on the market (read drysump) that won't be much more expensive than doing all of that. That being said I wouldn't run a drysump in a street driven car.
Reply 0
Aug 7, 2013 | 10:54 AM
  #81
^Add to that list a crank scrapper and overfilling by .5-1qt
There has got to be a better solution other than stepping up to a dry sump...
Reply 0
Aug 7, 2013 | 11:07 AM
  #82
Quote: Soon there will be a solution on the market (read drysump) that won't be much more expensive than doing all of that.
* confused dog head tilt? *
Reply 0
Aug 7, 2013 | 11:28 AM
  #83
I forgot the crank scraper, that's also on my list.
Reply 0
Aug 7, 2013 | 11:29 AM
  #84
Quote: * confused dog head tilt? *
I think MAP is working on a drysump kit for the Evo, might be what he's referring to.
Reply 0
Aug 7, 2013 | 12:01 PM
  #85
I can't say anything about who is developing it or official release dates, but I will have one of the first two pre-production kits in my hands in the next month or so
Reply 0
Aug 7, 2013 | 12:43 PM
  #86
Quote: I can't say anything about who is developing it or official release dates, but I will have one of the first two pre-production kits in my hands in the next month or so
You better put up a thorough and intelligent review of it, when you've had the ability to try it on track, or I might have to come out to SD, steal your car, and go test it out myself...
Reply 0
Aug 7, 2013 | 12:49 PM
  #87
Haha. There will be lots of pics and video/logs. I'm just hoping AIMsports stays with their 'new' ship date on the aim mxl2 which is slated for around when I should have the car back together.
Reply 0
Aug 7, 2013 | 01:25 PM
  #88
Quote: Soon there will be a solution on the market (read drysump) that won't be much more expensive than doing all of that. That being said I wouldn't run a drysump in a street driven car.
why wouldnt you run a drysump on a street driven car?
Reply 0
Aug 7, 2013 | 01:44 PM
  #89
Quote: why wouldnt you run a drysump on a street driven car?
It's a personal preference thing. Just seems a little over the top on street for me.
Can they be run successfully on the street? Yes. Would I? No.
Reply 0
Aug 7, 2013 | 02:21 PM
  #90
I'm guessing this is the MAP Dry Dump kit that they've been posting teaser pics of.
I just recently added a Kiggly and Cosworth Crank Scrapper, but have yet to test to see if its an improvement. I'll be sure to post up the before/after logs.
Reply 0
2  3  4  5  6  7  8  9  10  16
