Perfect Track Wheels Thread
Old Apr 12, 2011 | 05:58 AM
  #106
R/TErnie's Avatar
I'm working on making 18x10.5s fit with little to no exterior work.
The issue I'm finding is that I need 18x10.5 +32 to +34. And the two closest wheels that I've found are the +30 nto3 and the +31 sp1 professors.
Other than those it will be a custom wheel... Ccw and then get pretty expensive.
IMO the 18x10 rpf1 +38 is a great wheel, Especially with a 285 hoosier.
The +15 offset won't work in the rear, so that wheeloption is really lost unless you run a .5 staggered setup. 10.5 up front and 10 in the rear... Which I'll argue is better than a square set given the weight distribution. My 2 cents. Everything volk has is too low of an offset imo
Old Apr 12, 2011 | 06:02 AM
  #107
drewgray's Avatar
Sure it will. It just takes persuasion.
Old Apr 12, 2011 | 06:20 AM
  #108
4cdndctn's Avatar
Is anyone running the 18x10 rpf1 +38 setup and if so, what size spacer up front?
Old Apr 12, 2011 | 11:21 AM
  #109
AIREKone's Avatar
I run the 18x10 rpf1s with a 20mm spacer in the front.
Old Apr 12, 2011 | 11:25 AM
  #110
L888Apex's Avatar
Do you think it will be easy to fit a 18X10 +38 RPF1 with 265/35 tire then?
Old Apr 12, 2011 | 12:26 PM
  #111
PKEVO8's Avatar
One great track wheel that wasn't mentioned is the Kosei K1 TS. 17X8 weighs in at 15.5 lbs! I believe they are discontinued, but they are an excellent option for someone who is looking to retain a stock size wheel.
https://www.evolutionm.net/forums/ev...its-evo-2.html
Old Apr 12, 2011 | 10:39 PM
  #112
Loser's Avatar
Yep. I had the 17x8 for a couple of years but could never find a used set of 17x9. So I eventually sold those and got a set of Wedsport SA-70.
http://thepadayas.com/images//200909/01e1ed4.jpg
Old Apr 12, 2011 | 10:48 PM
  #113
R/TErnie's Avatar
Yes. 20mm spacer up front. Have coilovers and be prepared to run a 6" spring.
I ordered the perfect wheels today... 18x10.5 +38s. Now I just sit back and wait patiently.
Shameless plug... I'm selling my 18x10 +38 rpf1s w/ 20mm spacers. 295 r888s! I'll include a custom trailing link so you can run floppy hoosiers and not rub!
Old Apr 12, 2011 | 10:52 PM
  #114
L888Apex's Avatar
Okay doesn't seem too bad I'm guessing you are not going to say which ones you got are you? What size springs do most manufacturers put on their coilovers?
Old Apr 13, 2011 | 06:31 AM
  #115
boomn29's Avatar
Brand new Forgeline GA3R's in Matte Bronze.
They are lighter and stronger than my old set of ZX3R's; same size of 18x9.5"
http://www.forgeline.com/products/co...ries/ga3r.html
My scale shows them around 20lbs. (yeah, the Volks are still lighter).
Old Apr 13, 2011 | 06:46 AM
  #116
R/TErnie's Avatar
I ordered some ccw classics. Depends on the shocks. My skunk2 pro-cs and ohlins dfvs are both 2.5" springs.
Old Apr 13, 2011 | 07:03 AM
  #117
PKEVO8's Avatar
yeah they are extremely hard to find in other sizes. 17x9 would have been perfect! Either way these are still some of my favorite track wheels. And the dual valve stems for nitrogen filling is legit!
Old May 4, 2011 | 12:38 PM
  #118
EvoJoeRacing's Avatar
So i have read through this thread and going over the rim sizes and offsets that everyone is listing...
Follow my math here if and let me know if im right
9" rim = 229mm centerline is 114.5mm
9.5" = 241mm centerline is 120.5mm
10" = 254mm centerline is 127mm
10.5" = 267mm centerline 133.5mm
On the Evo IX... from what im looking at i see:
9.5" +35 and 10mm spacer = 120.5 + 35mm - 10mm = 145mm back spacing
9.5 +40 and 25mm spacer = 120.5 + 40mm -25mm =135.5mm back spacing
9.5 + 38 and 20mm spacer = 120.5 +38 -20mm = 138.5mm back spacing
10" + 38 = 127 +38 = 165mm backspacing
10.5" +32 = 133.5 +32 = 165.5mm back spacing.
From what i see is that we have about 140mm-160mm of space from the wheel hub to the most inner portion of the front before rubbing. Am I correct in assuming this? That 20mm is a big window (about an inch)
What level of clearance do we have in the rear to the inner most portion before rubbing?
Old May 4, 2011 | 02:08 PM
  #119
Murph's Avatar
Big plus 1 for the Wedsport TC105N! Bought a set last year. Well built, very light, and have enjoyed having them on the vehicle!
Murph
Old May 4, 2011 | 02:49 PM
  #120
EVOlutionary's Avatar
I think you got the math backward. You add the offset and subtract the spacer.
