Evolution Dynamics Pikes Peak Build
Old May 18, 2012 | 09:11 PM
  #121
KevinD's Avatar
Originally Posted by SmokingTires
Paint looks good! But maybe I'm a little bias towards Silver :-D
Now you just need some sweet C/F headlamp covers like I have and you're set!
i also have a set of the carbon headlight deletes i'll be running them for every event EXCEPT pikes peak, per the odd rule that dave just mentioned.
Originally Posted by Pirana
Kev, love the black/blue/red lines. I know its something everyone uses, but still love them!
thanks victor! there is only one other option with the fittings and its silver/black. the lines the only option is the black lines unless i went with stainless braided which are the worst to work with.
Originally Posted by DaveK
^ That looks awesome! If only we could in our class - there's some weird rules in place for Pikes Peak's version of "Time Attack" that differ from just about every other sanctioning body that runs TA styled events.
Dave
thats the silly rule that requires me to have headlights for pikes peak.
Old May 18, 2012 | 11:48 PM
  #122
KevinD's Avatar
more updates:
got the AP racing brake kit on the front! HUGE THANKS to ESSEX PARTS for making this awsome kit!!
some graphics added today:
and the rear brakes with the wheel on:
Old May 19, 2012 | 12:37 AM
  #123
Drifting Away's Avatar
soooo much win here....
Old May 19, 2012 | 06:30 AM
  #124
Pirana's Avatar
Thats what I like. I hate the silver/black. To stealthy for me
Old May 19, 2012 | 07:05 AM
  #125
jerdeitzel's Avatar
Car is looking good!
This hillclimb would be a good test and tune for you guys!
http://www.dragonhillclimb.com/
Old May 19, 2012 | 07:21 AM
  #126
Robevo RS's Avatar
I am actually planning to go there since i have been invited by a friend. But looks like i will have a schedlure problem. I have to go to st tropez a same time for work. Its an awesome climb. I try to make it there though.
Old May 19, 2012 | 07:24 AM
  #127
R/TErnie's Avatar
love the brakes! Good place to spend your money.
Old May 19, 2012 | 04:31 PM
  #128
Balrok's Avatar
Originally Posted by KevinD
more updates:
Oy, wth, Kev you KNOW that's been my number since I was at your shop last....2009......copycat...
Old May 19, 2012 | 05:49 PM
  #129
KevinD's Avatar
i know you run the numbers, and only REALLY fast cars are allowed to so your good to go
however, i do believe i might have had the 463 earlier then 2009 i used it last time this car was together which i think was in 1988
Old May 19, 2012 | 06:30 PM
  #130
R/TErnie's Avatar
646 is a better number anyway
Old May 19, 2012 | 06:37 PM
  #131
mayberry's Avatar
When installing a bigger brake set up in the front like the one pictured, does the brake pedal feel any different? I've driven cars with BBK's and the pedal felt like it started to grab at a lower position, like the master wasn't able to push enough fluid to fill the bigger calipers quick enough. It felt the same no matter how many times you bled the brakes. Or do the higher end BBK's account for this type of thing? Does anyone make a modified master cylinder? Is it necessary?
Also, is it recommended to do front and rear? I know these sound like noob questions, but I've never had to look into modifying the brakes to that extent, nor will I ever have to.
Great looking car by the way. I'm incredibly jealous of what you guys are doing. Congratulations, stay safe, and good luck!
Old May 20, 2012 | 03:08 AM
  #132
KevinD's Avatar
well after pulling an almost all-night nighter, we got the car fired up and were able to drive it around the parking lot a few times. small problem with my OBD2 connector wiring so i wasn't able to scale the injectors, but they were somewhat close so it runs and drives (just doesn't idle perfect).
on to the good stuff:
installing the core support after putting the engine in:
bumper is on:
under the hood:
lots of AN fittings:
all together after the mainden voyage:
we are borrowing Joshs wheels so we could see fitment with this size wheel/tire combo. we will be going with the black wheels when enkei decides to sponsor us
Old May 20, 2012 | 04:55 AM
  #133
Robevo RS's Avatar
are you guys still having an ABS, do i see it right?
Old May 20, 2012 | 07:44 AM
  #134
KevinD's Avatar
Yes you are seeing it correctly. I actually have the rs abs delete setup but the abs is pretty good so we are going to keep it.
Old May 20, 2012 | 10:40 AM
  #135
R/TErnie's Avatar
Are you going to make an air box for your air filter?
