Official AutoPower Roll Bar Thread
Old Dec 10, 2012 | 02:08 PM
  #76
jerdeitzel's Avatar
A roll bar is a great first step to safety. I would look into the plates for mounting tho.
Old Dec 10, 2012 | 02:14 PM
  #77
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Agreed.
Old Dec 10, 2012 | 03:25 PM
  #78
delongedoug's Avatar
Old Dec 10, 2012 | 03:31 PM
  #79
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Nice, those plates look good.
Old Dec 10, 2012 | 03:56 PM
  #80
I should note that with the additional 1/4", the roll bar borderline doesn't fit with the headliner since it fits so perfectly from Autopower.
Old Dec 10, 2012 | 04:53 PM
  #81
jerdeitzel's Avatar
Just order the sunroof model and you should be set!
Old Dec 10, 2012 | 06:18 PM
  #82
Macaroni's Avatar
delongedoug - Take some dry ice to that sound deadening get rid of that weight!
Old Dec 10, 2012 | 06:57 PM
  #83
jerdeitzel's Avatar
He is in CT. All he has to do is let the car sit outside in freezing temps and tada. It comes off as easy as can be. We at least get some benefits for living in the cold. lol
Old Dec 10, 2012 | 09:08 PM
  #84
qwertymess's Avatar
Would welding the AP roll bar to the chassis (Same points) 4 or 6 point provide more durability and strength than just the bolts?
If i had the AP race 4-point roll bar or 6-point welded in, as apposed to doing a custom 4 or 6 point cage, would either or be more or less secure?
I ask because i am at a crossroads now were as this is strictly a track car (Circuit Racing) and does not see the street. Looking for something that can pass for NASA time trials TTU, be turned into a full cage later down the line (Start off with a 4 point), be welded into place, and finally be just as safe as a custom 4 or 6 point.
An added bonus to this is that it keeps the costs down.
Input?
Old Dec 11, 2012 | 05:51 AM
  #85
Solenoid's Avatar
Veteran: Marine Corps
Input?
My .02
Welding in the AP roll bar would certainly provide a better mount, especially if the mounting feet were boxed-in to the body
The AP bar is spec'd w/ 1.750 x .120 DOM steel. I think a custom roll bar of the same configuration & spec would be similar in strength
Not sure about bar requirements w/ SCCA / NASA. Im just a track day guy
Mike
Old Dec 11, 2012 | 07:19 AM
  #86
jerdeitzel's Avatar
The AP roll bar is legal for SCCA level 3&4 time trials in the bolt in form. AP also sells a kit to add the front section to make a full cage. This is a bolt in option (needs to be welded to the main hoop tho) that is legal in both SCCA and NASA road racing. The biggest benefit of the AP system is the cost. You can get the full cage for under $1000. But, once you get into custom cages you will start to get into the $3000+ price range. The biggest thing between the two kind of cages is the fit. The AP front half of the cage comes straight down before the dash and mounts to the floor. A custom cages will be (or should be) designed to pretty much hug the roof and follow the A pillar much closer and can and should be mounted to the frame rails and not the floor. Either one is legal and will do the job. The custom cage will do a better job if you ever need it. An AP cage is still much better then nothing at all!
Old Dec 11, 2012 | 09:14 AM
  #87
qwertymess's Avatar
Thanks for the input Solenoid and jerdeitzel.
The AP roll bar than in my opinion is the way to go for the time being. Saves some cash and is legal for both SCCA and NASA, cant go wrong.
Old Dec 19, 2012 | 02:13 PM
  #88
EGbeater's Avatar
Very nice; good work! 1/4" is really thick... I'm certainly no engineer, but I'm thinking just a 1/8"-thick steel reinforcement base plate would still be a HUGE improvement in resisting punch-through of the paper-thin OEM floor, and that the roll bar would still (just barely) clear the roofliner.
Here are some crappy cell phone pics of my Autopower race bar installed (how-to install thread here):
And the car itself:
Old Dec 19, 2012 | 03:07 PM
  #89
^^^Wow, Awesome looking track day car
Guys, EGbeater has a great "How to" roll bar install here (Will add to front page)
https://www.evolutionm.net/forums/ev...l#post10567078
Old Dec 20, 2012 | 05:44 AM
  #90
xtnct's Avatar
Link to original thread related to the extra support plates to keep this thread complete:
https://www.evolutionm.net/forums/mo...ng-plates.html
