Official AutoPower Roll Bar Thread
No worries. I just was letting people know that you can get the roll bar in this configuration you see in the pic (non removable) or in the other pic you posted (removable). This can be done in either a cage or roll bar. So, this is not a good indication as to weather its a full cage or not.
I know what you do for work & that explains how you caught that detail
Is it possible to load 4 wheels with tires in the back seat with these bars? I need to carry a set of rcomps with me to events and see this being an issue. My rear seats have to stay in per class requirements, im happy in the class i am in so removal of the seats is not an option.
I see autopower has a street sport bar that has a removable harness bar which might work for me,
Is there anyone using this? If so can you shoot some pics of it?
^^^Ive tried & dimensionally will not fit between the main hoop vertical bar & the angled rear legs (Loading from the rear doors)
Maybe if you tried loading the tires from the front seat, up & over the horizontal bar into the rear.
Its going to be a PITA if its even possible. Maybe the other guys have some ideas
BTW: I located the guy that was fabbing the rear tow hitches only to find he wont make them anymore. Im interested in pulling a small gear trailer
However, it MIGHT be possible with significantly smaller/narrower tires than the 285/30-18 Hoosiers I have, like 235/40-17 or a 245/40-17.
I wish it were possible for me to fit three wheels/tires in the Evo 8/9's trunk. Then I could strap the fourth wheel/tire into the front passenger seat, and load my fuel jugs into the back seat area (also less than convenient as the jugs are awkward and heavy when they're full of E85).
So you must have it for looks... ??? Haha just kidding
Ah ok. That makes sense. I suppose it's safer either way but didn't know that it passes scca specs.
You do not need to run the extra plates to pass SCCA tech. The way the bar is designed from the factory passes tech. The extra plates are just things people do on their own to make the bar safer.
