Buschur Baffled Modified OEM Oil Pan Question
So after reading a few threads it seems like there are a few must have's for track days when on R-comps/RS3's or better.
Baffled pan
5 qt of some quality 20/50 oil
Kiggly HLA pressure regulator
Setrab or bigger oil cooler ( does anyone remember the name of the core that setrab is relabeling,There is a thread somewhere about it)
The Tomei oil temp thermostat killer doesn't seem like it would help because once you have a lap or two in the oil temp is over 170. Unless there is a flow concern with the stock thermostat. Does anyone have a good data on that?
Not to high jack this thread but when is the stock radiator a problem with road courses? Is there a recommended HP limit for it? What is the best radiator to replace it with?
Baffled pan
Best radiators seem to be cbrd double pass race radiators, and also using heat reflective wrap (gold stuff) on head facing the turbo/cam sensor/all cold side piping/etc, turbo blanket, and heat wrap (headers/exhaust).
Not as much a one part thing as a system of heat control
i think 20w50 is overkill, ive been running amsoil 10w40 high zinc without issue. after my 60k service the shop put in 5w30 brad penn i think, and id get a flickering oil light coming to a stop clutched in on the street in 80+ degrees. that doesnt happen with the 10w40.
changing my radiator cap (brand new stock) made a noticeable difference in the level in my overflow tank after a track session, and the dash needle sits lower.
last weekend was the first time ive had oil temps (measured in the pan) rise above 190. it was 80ish degrees out and a little humid combined with an instructor flogging my car and then hot pitting to switch drivers. it was a tad above 200 on pit in and sitting still let it climb to about 220. once moving it dropped at least 10degrees.
there is a heat reflective tape called aerolite that is >90% reflective, while the gold stuff is something like 40% reflective. ill be wrapping some stuff with it soon. oil cooler is the big piece of the puzzle for next season.
I haven't read of too many people doing that. Are you talking about polishing the oil return passages smooth? I guess theoretically it would help oil return from the head. I know Eric did that when he built his 4G64 2.2L. I doubt anyone has any information on how much it actually helped. I would think the oil would create a "layer" over the imperfections that the other oil would flow smoothly over
Someone could send an email to AMS asking them if they do that on their AMS2.3RR or other race engines...
Dan
Before this escalates further, Balrok's post has already answered the question. Some are flat, some aren't. The shops who install them a lot, know what to check, and how to get them to seal. We've had a few folks who track them here in the NW, with no issues due to ER , West Werks etc. having done enough of them to be familiar with installing them correctly. I have this piece on my car as well (installed by ER), just didn't want to chime in since I haven't tracked the car since getting it...and i've only had it for about 8 months with no leaks.
It's not just a hp limit as much as a conditions limit. How hot is it? How long of sessions are you running? Power? Oil cooling efficiency (read high capacity pan/oil cooler etc), how high are you rev'ing the motor? Etc
90*
30 minutes
420whp FP red 100 oct/ETS 3.5
Stock pan/stock rad
6500rpm
RS-3 tires
Does this seem doable for a 3.5 mile course?
I will look into the gold tape.
IMO you'll be fine. If you're doing lapping/non-competitive stuff, I would do a cool down lap after a few hot laps to give everything a little break.
I ran similar power in 20 min sessions with no problems on street tires. I do take my car to 8k though, quite often due to the layout of Portland Int'l Raceway though. I find my car is RARELY below 6k when I'm pushing it. I haven't been at 421 HP without slicks and the oilpan. I bought my first set at the same time as the pan for safety.
boomn29
Jul 8, 2019 05:09 PM
David Buschur
83
May 27, 2016 07:39 AM
rs03evo
Sep 25, 2013 11:25 PM
Pure EvoIX
62
Jul 2, 2013 01:54 PM
