Öhlins THAT much better?
Did you happen to do Roll Center / FAP calls to get your ride heights, or just go low and flat? I'd guess you put some thinking into your setup...
I wish I remembered my FSAE classes better + measured everything when it's been apart...
I haven't bothered going that far into evaluating the evo stuff yet. Really cause there hasn't been any big reason to since we cant to a whole lot about it. The whiteline RCK really only compensates for 5/8" of lowering IIRC but 5/8" is better than nothing. More so just going into the set up as get the rear nearly as low as possible and run enough roll rate to control the car motion. Set the front a little higher since that has a worse geometry which is pretty obvious looking at the control arm angles. Also to reduce the rake a bit cause Evos are quite nose-down.
There are some other things I've been thinking about lately cause a 240 buddy, namely slider axis and how to get effective camber gain under bump. If I ever get some of these "Secret" projects further along I might post up some progress but for now I'm just slowly working away on the design side of things.
My current setup I went a different route. A bigger reason for the added caster is to re-center the wheel after the PSRS offset bushing pushes it forward.
Attachment 326970
Ive done that on other setups, just max the camber on the top and pull out camber as needed at the hubs. If theres a balance issue left/right then the subframe needs to be adjusted.
Im going to look into doing that for next year. I didnt think it was possible to get enough camber having the bolt at the -1 setting without the spring perch making contact with the inner fender well... Are you massaging the inner fender well or am I just crazy? Im having rubbing right now actually but it may just be my brake lines. As long as I can get around 3.5 degrees in the front I will be happy.
after a long classroom discussion with other drivers and a few instructors last weekend, i learned a little of why ohlins matter.
out of a large group of vastly different cars i was the only one that could eat up curbs. many people were being told to stay off the curbs, but the group leader/very experienced instructor drove a few laps behind me with his high end data/vid system. when we reviewed it it was very apparent how much better my car soaked up bumps than any everyone else, to the point that i was making time on exit over every other car because of it.
