EVO X LCA on 8/9
Old Nov 23, 2015 | 03:23 PM
  #31
03whitegsr's Avatar
Seems like getting a male threaded rod end and a coupling nut would be 1000x easier?
FWIW, I know people have talked about concerns on axle length with this, but when I tore my axle apart there was a small amount of wear showing the end of the axle had actually contacted the axle cup. I am sure it happened while I had my camber maxed out around 3.5-4* but if you are in that range often, seems like pulling the hub out a 1/2" might be a good thing for the axle.
Old Nov 23, 2015 | 05:25 PM
  #32
killerpenguin21's Avatar
I haven't had any luck finding a female to male coupler. Also don't know how long it actually needs to be...
Old Nov 24, 2015 | 11:05 AM
  #33
03whitegsr's Avatar
Use a male rod end and then it's just a coupling nut?
Not saying this is exactly what you need...but they are available in metric sizes.
Metric Male M14x1.5 Rod End
Old Nov 25, 2015 | 06:06 AM
  #34
Issue is the necessary extension is less than I pictured. Pics from full race Geoff
He mentions cutting down stock tie rods as part of his extension fab, but I can't tell exactly what he did...sort of looks like he cut a chunk out of another tie rod and welded on some threaded rod?
Old Nov 25, 2015 | 11:46 AM
  #35
TheBoz's Avatar
I pick up my stuff from Robi on Friday. I was out on vacation for the last 2 weeks. But now I am back and ready to get this damn car back together. As soon as I have all the parts I will post up some pics.
Old Nov 25, 2015 | 01:32 PM
  #36
03whitegsr's Avatar
So worth mentioning here, in the suspension forum on the "drop spindle" thread their are some difference on the X upright that could be of interest too in this discussion.
Old Nov 25, 2015 | 01:42 PM
  #37
LetsGetThisDone's Avatar
Originally Posted by psushoe
My DIY bump steer kit. I used a female m14x1.5 rod end and extended it. I machined a piece and tapped it m14x1.5. Then i threaded it and the rod end onto a bolt and welded it. Remove bolt, chase threads and paint it. Just gotta be careful not to overheat the rod end when welding and deform the teflon. I drilled out the taper on the knuckle so the bolt would pass and used washers to get the tie rod angle right. Then I machined a spacer from 6061 for the permanent solution.
I would personally never feel safe with that on my car. You didn't even put a proper grip length bolt in it, so you're subjecting the threaded portion of the bolt to shearing forces. And a lock washer instead of a metal-metal lock nut. *scaredface*
Old Nov 25, 2015 | 03:38 PM
  #38
psushoe's Avatar
Pretty cool you can see the bolt shank from those pics. Can you also tell the bolt is a different length in each pic? Pics were taken during fit testing. Thanks for the internet design evaluation, though. ;-)
Old Nov 25, 2015 | 09:08 PM
  #39
Unless you buy aircraft bolts to length, you have to cut the excess threads off of a hardware store bolt if you want the proper grip length. And since you're not using an aircraft locknut, it's a good bet that's not an aircraft bolt.
I wouldn't run something like that without doubt blue shearing it. Regardless of the bolt.
Old Nov 25, 2015 | 10:10 PM
  #40
03whitegsr's Avatar
Would be a good idea to add a safety washer on there should the tie-rod end fail.
Not using a tapered fit into the hub and using a coarse thread is giving up a lot of strength though Looks like a grade 5 bolt?
Old Nov 26, 2015 | 08:51 AM
  #41
In the on me pic, the head looks metric, probably 8.8..
Old Nov 26, 2015 | 09:24 AM
  #42
psushoe's Avatar
Metric 8.8 with 92,000 psi yield. It is 14mm to match the rod end, which is larger than the factory thread on the end of the tapered tie rod end. I drilled out the taper to get a straight fit with the bolt shank. The machined spacer fits flush on the rod end and kuckle side to maximize clamp area when the bolt is torqued. The bolt load when tighted should be in the axial direction if done properly, not shear. That is taken by the through bolted material. This is different than the tapered stock rod end, where the shear load is in the bolt/taper because it is one piece. The spacer is T6061T6. As for extra security, the free end of the bolt through the nut can always be drilled for a cotter pin or wire... you don't have to buy aircraft bolts to get that feature.
Old Dec 7, 2015 | 02:04 PM
  #43
03whitegsr's Avatar
The safety washer isn't about it loosening up. It's about the rod-end failing. A safety washer prevents a failed rod end from becoming two separate pieces should the ball pull out of the race. Sounds unlikely, but once you get some wear, this is the common failure mode.
As for the design, like all things race car, I'm sure you'll keep an eye on it either way. Keep an eye out for fretting wear on that spacer. Any fretting wear means the bolt is seeing bending loads.
If it's better or worse then a tapered bolt setup, it's hard to say. I wouldn't think what you have will run into issues, but if you do, it will be due to bending loads in that fastener.
Old Dec 8, 2015 | 02:33 PM
  #44
psushoe's Avatar
Safety washer = OD bigger than race so it cannot pull out. Makes sense. I was focused on loose fasteners. Will add to winter upgrade list. Thanks!
Old Dec 8, 2015 | 04:27 PM
  #45
My comment on it being an aircraft bolt, or not, was related to grip length.
Standard bolts are sold by underhead length, so 99 times out of 100, in order to have proper grip length, you end up with a bunch of extra threaded length. Your picture showed a normal amount of extra threads, but the bolt wasn't cut down, and since you had a regular nut on it, I assumed it wasn't an aircraft bolt. I'm sure you know that you can order aircraft bolts by grip length. It had nothing to do with a cotter pin feature. And that's not even why aircraft nuts have the castle nut look, They are made that way because they are a metal/metal lock nut, but they don't harm the threads like a typical stover nut tends to do, due to that design.
I would still never run something like that in single shear.
