EVO X LCA on 8/9
thatll be my back up plan. ive got a length of threaded rod that i was planning to use to make sure all the threads line up straight and such between tie rod and extended. i like the sleeves i ordered because they are very heavy duty, they should be here friday.
my issue right now is that one of my whiteline balljoints crumbled to pieces when the shop tried to press it so im waiting to hear back from whiteline...and i cant get the damn tie rods to slip outta the hubs.
well crap. turns out the tie rod sleeves arent fully threaded like i was told they were, they only have about 1 inch of thread on one end of the sleeve. due to being stainless and an inch thick, im not convinced that it could be welded to the tie rod but ill talk to my shop monday...not to keen on welding anyway.
the mooresport nut looks very useful, but i dont think it is long enough to do something like put it on then end of a piece of threaded rod and still have a reasonable amount of threads left to grab onto the steering rod....
back to the drawing board...
- steering rod is confirmed as m14x1.5
- tie rod to hub is confirmed m10x1.25
i had m10x1, x1.25, and x1.5 i was trying to fit and it really looked like 1.25 but for whatever reason it wouldnt thread onto my whiteline pieces. one i knew it wouldnt because i hammered on it too hard and mushroomed it. i went and got a new ball joint tool and thought my other one would be fine, but when i looked closely the new tool had ruined the top thread so nothing would start to thread on. the 1.25 then went right on when i put an oem tie rod back on the car.
im going back to my plan of sacrificing old ball joints to make the extender since i have two trashed whiteline ones now and a new kit waiting to be picked up. should have it all together by end of the week...hopefully.
had to delay my install a few days so i could work on the tune in an attempt to squeeze in a dyno session sometime this week.
all my parts are ready to go tho...
I got one arm installed tonight. unfortunately my extension idea failed, as it didnt allow the tie rod to thread far enough on and i had massive toe in.
HOWEVER, i installed the tie rod without extension and was able to get the toe zero'd. when i took everything apart, my tie rods were threaded on 10 turns. i got the toe zero'd with them 5 turns on, which kind of surprised me based on pictures ive seen.
the question is just if thats enough...
not sure where to go from here...the cut off section of tie rod doesnt have a flat edge so im not sure it can be weded now (i didnt even do the cutting i had a shop do it...)
