evo 9 hillclimb build log
Old Dec 29, 2022 | 02:47 PM
  #421
LetsGetThisDone's Avatar
I think thats eventually where all budget builds somehow end up..
Ah ok. Unfortunately end of Feb wouldn't be doable for us.
Old Dec 30, 2022 | 10:36 AM
  #422
Balrok's Avatar
Originally Posted by Meathooker
tom at TS comp did the first motor. Seemed alight but it’s super hard to get ahold of him.
English did the stroker in the budget build earlier this year. They were good and the motor works well but they refuse to reuse any parts in a rebuild that aren’t theirs.
Arlington has good feedback and is willing to reuse rods/crank if they’re still in good shape.
Do you have any feedback on them?
No I was curious who the next go to is. I don't want a shop I have to babysit on the next one. STM's are...ookk. MAP's are soso. I really liked the response the 10.5:1 CB built for me. OEM's are great and last forever but are a bit slower.
Old Dec 30, 2022 | 12:59 PM
  #423
Meathooker's Avatar
this is not an exaggeration - i would not run a MAP motor if it was free.
English was great - no baby sitting and the work is top notch.
Old Feb 10, 2023 | 05:42 AM
  #424
Meathooker's Avatar
got most of the car pulled apart and power washed out. Painting the cage with Steel-it and re assembling.
Old Feb 10, 2023 | 04:02 PM
  #425
Dallas J's Avatar
Veteran: Army
Some day I want to strip my car down that deep and really just put back whats needed. Re-do all the wiring and all that fun stuff.
Old Feb 10, 2023 | 06:00 PM
  #426
Meathooker's Avatar
Join the party!
Old Feb 10, 2023 | 07:14 PM
  #427
griceiv's Avatar
so are you putting a big *** diffuser in the back? looks like the trunk floor is cut out.
Old Feb 10, 2023 | 07:55 PM
  #428
Meathooker's Avatar
eventually. For now probably just put a sheetmetal panel there.
the list for this year is long enough just to get it back out
Old Feb 10, 2023 | 08:48 PM
  #429
Meathooker's Avatar
would that be SM legal? Or switching classes?
Old Feb 11, 2023 | 08:55 AM
  #430
Dallas J's Avatar
Veteran: Army
Stripping and simplifying the harness is certainly legal. Then there's just a lot of simplification in the wiring and how things are run that can be improved. Like the ACD pump wires running to the front then re-routed to the back. Or the battery power routing once I get the battery moved.
What do people do to clean up the wiring going to the fuse panel in the engine bay?
Old Feb 22, 2023 | 05:55 AM
  #431
Meathooker's Avatar
i bet you could pull 30-40 lbs out of the car in wiring.
bryant s putting in the motec PDM that replaces the fuse panel. Cleans it up a LOT
Old Feb 27, 2023 | 09:22 AM
  #432
Bee-Raddd's Avatar
This is a very very big dark hole your about to fall down into haha.
The fuse panel is actually super complicated once you try get into it all. especially with the ETACS ecu etc.
Best thing is just cut and strip any wiring you dont need out. things like all the wiring to the power windows etc if uve stripped the doors. speaker wiring etc etc.
Be careful with anything to do with the ACD as it is so easy to introduce a fault from changing a wiring routing or length etc it seems super sensitive.
The headaches you can introduce from tampering with the wiring outweigh the advantages of the weight savings it gives you in hindsight.
Old Mar 1, 2023 | 10:13 PM
  #433
Meathooker's Avatar
a very dark and very expensive hole.
we’re planning to use the Emtron to control the acd. I’m nervous how it’s going to work.
Old Mar 2, 2023 | 05:31 AM
  #434
Ayoustin's Avatar
This is where my inner caveman is happy to have a non ACD car lol
Old Mar 2, 2023 | 09:35 AM
  #435
Dallas J's Avatar
Veteran: Army
If you have a good front and rear diff, the viscous works pretty well.
I gotta figure out some motec things so I can add the steering axis to the throttle/braking tables.
