Spinning front, inside tire.
Old Sep 2, 2019 | 01:05 PM
  #241
kaj's Avatar
kaj
Originally Posted by kikiturbo
main difference is that the clutch type diffs lock even with one wheel in the air, while the helical diffs will act as an open diff when one wheel goes up in the air..
Not if you ask Weir.
Originally Posted by alpinaturbo
And S2000 is very very capable track-day/track car in OEM form with that (Torsen with diff (perhaps rear toe arms off second-gen F22C car to minimize toe-change).
I frequently keep my eye out for an S2k, still... I was thinking to pony up for the AP2 to get the better suspension.... is swapping the toe arms out all it takes to correct the AP1's short comings? Well, other than the oil pump issue, I mean
Old Sep 2, 2019 | 01:53 PM
  #242
kyoo's Avatar
torsen actually does become open when one wheel is up. wavetrac apparently does not. helical does not. clutch types do not.
is clutch superior to helical? probably, but i also don't expect life changing or even suspension setup changing performance
Old Sep 2, 2019 | 01:54 PM
  #243
kyoo's Avatar
00-05 is a nightmare to tune. 06+ ap2 is the way to go for track/modifications
Old Sep 2, 2019 | 04:16 PM
  #244
kikiturbo's Avatar
torsen and helical are a similar thing... both do the locking thing by the virtue of sliding helical gears.. it is just the design that is different... both provide no real locking with one wheel in the air and both are a bit unpredictable in those situations.. hence, that is why you do not see torsens/helical diffs in racing situations... but they are much nicer on the road.. Plate diff in the FWD car is a nasty thing if you do not pay attention.. It will tend to pull in abruptly if you are too slow in a corner..
I drove the ralliart front and rear plated diff e9, but that was a full monty grN car so hard to draw conclusions. Predictability might be the main thing as it is more precise than the stock combo.. On my car we will try plated front ralliart diff (with lowered preload) with ACD and AYC rear... that might be weird..
Old Sep 2, 2019 | 04:18 PM
  #245
kikiturbo's Avatar
biggest disappointment of my life... so glad it was a press car and not one I wanted to buy.. .heheheh
Old Sep 2, 2019 | 07:45 PM
  #246
alpinaturbo's Avatar
So,
Gr N Ralliart Equipped full pukka Evo 9:
how did it rotate without hand-brake?
Did it push or ? On Tarmac.
Old Sep 2, 2019 | 08:36 PM
  #247
kaj's Avatar
kaj
I honestly wouldn't be tuning the engine, anyway. Power levels would remain stock.
Old Sep 2, 2019 | 09:10 PM
  #248
Lumpy Sticks's Avatar
5 Year Member
My buddy has a bone stock low mile 06 for sale right now. PM me if you are truly interested in one.
Old Sep 2, 2019 | 09:55 PM
  #249
kaj's Avatar
kaj
Already sounds like it's out of my price range.
Old Sep 3, 2019 | 10:41 AM
  #250
5 Year Member
I think he wants around $18k...
Old Sep 3, 2019 | 04:01 PM
  #251
kaj's Avatar
kaj
Hm. That's not bad at all. Please PM the info. I'm about to make either a MAJOR automotive purchase or go the fun S2k/FD route... I haven't decided. If a good deal, either way, fell into my lap..that would make the decision a LOT simpler LOL.
Old Sep 12, 2019 | 12:51 PM
  #252
kyoo's Avatar
what's the appropriate setting for a front 1-way clutch for track, and for autox? 60% of plates activated?
Old Sep 12, 2019 | 10:55 PM
  #253
Ayoustin's Avatar
There's no one correct answer. It depends on the driver style, how much power the car makes, how tight of turns you deal with most. That's a question best asked to the person building your diff.
Old Sep 13, 2019 | 08:03 AM
  #254
Dallas J's Avatar
Veteran: Army
The wavetrac is marketing hype on that preload. And the preload isnt like a multiplier to the lockup, its just straight added to it. So if you have one wheel in the air, no matter what style of diff it is you still only have the lockup torque being able to transfer power.
I would bias it to as little as you can get away with. Just know that if you do spin up an inside front, you're going to probably roast that inside edge and the bounce of the torque as the center locks up from slip (either ACD or viscous) may be a cause of inducing hop. I'll learn more though next year when Im logging wheel speed with my runs.
Old Sep 13, 2019 | 08:18 AM
  #255
kyoo's Avatar
figures.. i think for me, on track, i should be able to get away with not using too much, and just be smoother with my throttle application post trail-brake.
if this is the case though, what's so transformative about having a front diff that people are talking about?
