Spinning front, inside tire.
Old Jan 17, 2019 | 12:01 AM
  #181
LetsGetThisDone's Avatar
The bolts were talking about that get upgraded are the ones that hold the tcase together. Not the ones the bolt the tcase to the trans.
Old Jan 20, 2019 | 06:05 PM
  #182
Bee-Raddd's Avatar
ah right. never had an issue with those coming loose either?
Old Jan 20, 2019 | 09:34 PM
  #183
kaj's Avatar
kaj
speaking of t-cases...
My ACD pump was making crazy noises. I check the fluid level and it's a finger width below "LOW". How in hell did I go from right at full to that, after swapping transmissions? I've never lost fluid swapping before. the t-case pretty much remained near level the whole time in the car. The line never came loose and the bleeder was solid. Weird.
Old Jan 20, 2019 | 10:23 PM
  #184
Dallas J's Avatar
Veteran: Army
My level seems to move quite a bit depending on heat. At the end of a dual driven AX in hot weather I believe the fluid ends up being low looking bases on reservoir. And when its cold and been sitting a while it will be nearly overfull. Im pretty sure if I had air in the system I'd get an error and Ive flushed the hell out of it after the relocation. So I think its just how it works out possibly effected by the thermal expansion of the system? Just a guess though.
Old Jan 20, 2019 | 10:48 PM
  #185
kaj's Avatar
kaj
Honestly ,I'm not sure. I'm hoping the buzzing was just due to air sonehow getting into the system and now that I bled it. It'll be quiet. I ran the car on jack stands and no noise. Fingers crossed.
Possibly it was low because of temp and it hadn't had time to fill the reservoir after I drove it.
**edit: it's overflowing with a puddle under the car LOL. I completely forgot to meet the car sit before checking the fluid level. LOL
Old Jan 21, 2019 | 02:56 AM
  #186
kikiturbo's Avatar
it is normal for the fluid to come back from the high pressure reservoar in the pump back into the plastic reservoar after the car has been sitting for a while... usually the difference is between full bottle and somewhere above min...
Old Jan 21, 2019 | 11:05 AM
  #187
kaj's Avatar
kaj
Yes. And it is important to not forget this when you happen to look over at the fluid level.
Old Jan 21, 2019 | 12:08 PM
  #188
kikiturbo's Avatar
I just overfill and let it drip out... prevents the rust.. LOL
Old Jan 21, 2019 | 12:31 PM
  #189
kaj's Avatar
kaj
Old Jan 21, 2019 | 12:39 PM
  #190
Dallas J's Avatar
Veteran: Army
That ACD fluid (which is pretty much ATF fluid) smells so damn bad. I def wouldn't want mine to overflow and leak with the res in the trunk.
Old Jan 21, 2019 | 12:49 PM
  #191
V.8MR's Avatar
Been there. Top off after driving. Come to garage the next day to a mess. Check level after a drive and sit overnight seems to be the best way to get it right.
Old Jan 21, 2019 | 01:11 PM
  #192
kaj's Avatar
kaj
at least it would be contained....? I have to back my car and do mop-up duty. bleh.
yep. it totally slipped my mind until last night. Then, I though, "Oh ****!". And, there was the puddle haha.
Old Jan 22, 2019 | 01:30 AM
  #193
kikiturbo's Avatar
yeah, I use synthetic ATF in mine.. Having said that, some mineral gear oils really smell bad..
Old Jan 22, 2019 | 12:40 PM
  #194
Ayoustin's Avatar
I've found not having an ACD system tends to help with that problem
Old Jan 22, 2019 | 11:27 PM
  #195
kikiturbo's Avatar
yeah, but if you like to drive a lot in the loose, the ACD, and especially AYC equipped cars work just that much better.... I wouldn't have one without it..
