Spinning front, inside tire.
Old Jan 13, 2019 | 07:21 AM
  #166
kikiturbo's Avatar
Originally Posted by Dallas J
If you were super worried, you could do a cooler/filter pump for trans and modify case to spray 4th gear (I think thats the one that needs it) directly. Win on all front other than weight/complexity. For AX or TA though, I'll just stick with things as they are unless a sequential falls in my lap.
trans cooler is ready, ever since I thought I would stay with a 6 spd..
Old Jan 13, 2019 | 10:59 AM
  #167
Dallas J's Avatar
Veteran: Army
Trans cooler has always interested me. If you get one setup, I would love to see pics of what/how you did it.
Old Jan 13, 2019 | 11:05 AM
  #168
LetsGetThisDone's Avatar
Originally Posted by ayoustin
I didn't say TRE doesn't build stuff for drag cars. I was just saying the other two (who offer these upgrades) don't do nearly as many road course builds compared to drag stuff.
My point was more the upgraded ring and pinions aren't needed. Especially not the "stage 2" gearset, it's just a made in China gearset. The stage 3 albins gearset is cool, but not exactly needed. And it's soft like "pro gears" for drag racing, so not road course even street use friendly.
Old Jan 13, 2019 | 11:24 AM
  #169
kaj's Avatar
kaj
Me too, please. I got as far as finding banjo fittings for my fill and drain holes and researching a pump that could move the fluid... but I can't find any of the info. I don't think I NEED a cooler for my HPDE days.... but I wouldn't mind adding one anyway.
Old Jan 13, 2019 | 11:37 PM
  #170
kikiturbo's Avatar
key is finding a cheap gear pump... I got one from marco.it and I think they have a US distributor... Staying away from "motorsport" stuff is the key to low price..
http://www.depcopump.com/datasheets/...c_Brochure.pdf
I dont have banjos.. just some metric to 10AN adapters and Setrab oil cooler..
Old Jan 14, 2019 | 08:04 AM
  #171
Construct's Avatar
What's the story with this 8mm to 10mm transfer case bolt upgrade? Is the 8mm bolt a genuine concern for reasonable power levels?
I'm trying to find the lowest common denominator among all the different rulesets that might apply here. Not entirely sure if the 8mm to 10mm bolt upgrade would be Autocross ASP legal if I wanted to go that route in the future. Trying to stay out of SM here, otherwise I have to give Dallas all of my money for fancy suspension parts.
Old Jan 14, 2019 | 08:18 AM
  #172
Ayoustin's Avatar
It should be legal. I believe it falls under the reliability rule they came out with last year. You can make things stronger as long as it doesn't provide a performance benefit.
Old Jan 14, 2019 | 09:02 AM
  #173
CaptainSquirts's Avatar
How about the clutch. Like going from oem to ACT HDSS. Does that mod not bump you into SM anymore?
Old Jan 14, 2019 | 10:01 AM
  #174
Dallas J's Avatar
Veteran: Army
Clutch is totally fine in ASP. You can run a twin as well there. Just not in STU.
Old Jan 16, 2019 | 09:49 AM
  #175
Bee-Raddd's Avatar
I run 520kw at the wheels and i dont seem to have issues? i do have to tighten them every couple rounds but thats all.
Old Jan 16, 2019 | 09:54 AM
  #176
Ayoustin's Avatar
You open up your tcase and retorque all the bolts inside it every couple rounds?
If things are loosening inside the tcase something is wrong lol
Old Jan 16, 2019 | 10:18 AM
  #177
The bolts he's referring to are the external bolts.
Old Jan 16, 2019 | 11:03 AM
  #178
Ayoustin's Avatar
Wow this is the biggest derp moment I've had in a while... I'm mixed up with another car where the tcase upgrades consist of enlarging the internal cap bolts.
Old Jan 16, 2019 | 11:17 AM
  #179
I mean, those shouldn't really be coming loose either though
Old Jan 16, 2019 | 05:20 PM
  #180
Bee-Raddd's Avatar
haha yea external bolts. TBH could probably put longer bolts in with a nut on the other side as they all poke through the other side of the bellhousing but you might end up breaking the casting. I put my driveline thru hell and ive only ever broken a crown wheel and pinion once.
