Old Mar 16, 2021 | 06:31 PM
  #2926
Dallas J's Avatar
Veteran: Army
All this talk about Evos being super forgiving and easy on track just sounds like opportunity to be fast with more rear spring and more front grip. But thats just me :P
Old Mar 16, 2021 | 06:47 PM
  #2927
griceiv's Avatar
Talking
Originally Posted by dallas j
all this talk about evos being super forgiving and easy on track just sounds like opportunity to be fast with more rear spring and more front grip. But thats just me
+1
Old Mar 16, 2021 | 08:26 PM
  #2928
Mivec4G's Avatar
Lol remind me of my 180sx with LS3 in it, talking about tail happy, wife ban RWD car after my second crashed on 240sx. I got TRE rear diff “max lock” I’m pretty excited about that cannot wait until it broke in. maybe adding stiffer springs and stiffer sway bar,
Old Mar 16, 2021 | 08:35 PM
  #2929
Mivec4G's Avatar
I used to run wisefab in my 240sx those are nice, but I think “Dallas J” your look so much nicer, have you think about make some for 240sx, since Evo and 240sx are similar suspensions set up,
Old Mar 17, 2021 | 05:57 AM
  #2930
Jacblack's Avatar
I feel like my car is never going to be done......
Old Mar 17, 2021 | 07:22 AM
  #2931
Balrok's Avatar
They never are lol.
Old Mar 17, 2021 | 02:39 PM
  #2932
Kevin.'s Avatar
What do y'all lube your shifter cables with, if at all?
Under the hood and at the shifter base. I'm having a problem with the shifter not returning to center. Thinking of using CRC Power Lube whatever disperses water on the cable and at the trans. What bout where the shifter ball pivots in the plastic retainer? Also wondering if that scissor clip (24093) wearing out could be the culprit.
WD40 is a solvent tho and not a lubricant White lithium perhaps?
Old Mar 17, 2021 | 06:17 PM
  #2933
kaj's Avatar
kaj
Mine has been done for a couple years now.. but.. .of course.. it's inevitable: I'm redoing things. a LOT of things it's just how it goes.
Lube the cables? Wussat? I'd check the shift mechanism on the trans itself.
Old Mar 17, 2021 | 07:28 PM
  #2934
Dallas J's Avatar
Veteran: Army
Thanks! I really really like the 240 platform but just the age and obvious typical use for it really doesn't leave much room for pure track car builds. Which is sad cause it really is a platform that would be great. I get excited every time a see a proper clean build on the street but its super rare.
Old Mar 17, 2021 | 10:22 PM
  #2935
kyoo's Avatar
the thing i've noticed with my setup (on track) is, when the tires are cold, the evo is loose as hell - dangerously so. as soon as the tires are hot, the car pushes a lot. may need some changes in balance or something, not sure. autox, i dont really notice
Old Mar 18, 2021 | 06:34 AM
  #2936
Jacblack's Avatar
Originally Posted by Balrok
They never are lol.
It’s been legit one thing after another, something new every week. I’m at my wits end at this point.
Old Mar 18, 2021 | 06:57 AM
  #2937
Turtletron's Avatar
5 Year Member
My car pushes a ton with 10k/12k springs and a whiteline rear bar on the middle setting. I tried out an ACD tune and put the bar on full stiff and while it wasn't as bad it was also spooky at speed. At this point I figure it's just the nature of the beast and my love affair with rwd.
On the plus side the car is very easy to just jump in and drive even with 400whp. My 140whp NC is a handful in comparison.
Old Mar 18, 2021 | 07:46 AM
  #2938
kaj's Avatar
kaj
. My setup is pretty mild compared to most and rarely get understeer. When I do, it's my fault. Maybe there is a learning curve going to AWD....?
There's a lot of demand on our front tires vs RWD.
Old Mar 18, 2021 | 09:41 AM
  #2939
kyoo's Avatar
im not worried so much about the general tendency of the car as the stark difference between hwo the car behaves when tires are cold/hot. cold - wild oversteer; hot - mild understeer
Old Mar 18, 2021 | 10:14 AM
  #2940
kaj's Avatar
kaj
That's par for the course, I think. On my out laps, I have to be very careful. Very.
