Old Aug 30, 2021 | 06:21 AM
  #3616
Terror Rising's Avatar
Does anyone know where to find 2" NACA ducts? If running large radial mount calipers there's plenty of room for 3" but otherwise you're stuck on 2" nozzles on factory brownbos.
Old Aug 30, 2021 | 08:07 AM
  #3617
ViciousLSD's Avatar
https://www.ebay.com/itm/36156342614...wAAOSwqMtdlznU
https://www.ebay.com/itm/30363129890...EAAOSwgGJeE2fY
see you at the track!
Old Aug 30, 2021 | 10:17 AM
  #3618
ViciousLSD's Avatar
The last time i played with NACA ducts/brake cooling was on my 1.8t A4 (see lower bumper) with stock calipers. I even tried fans directly on the dust shields before i got Stoptech brakes
I was not expecting to have similar issues with the evo, though I think this time my autox brake pads are just too aggressive for TT.
Old Aug 30, 2021 | 12:00 PM
  #3619
I always forget that ebay exists and could never find the 2" NACAs on Pegasus, Summit, etc. I've had ducting solved for a while by relocating the oil cooler and adding blockoff plates with duct inlets onto the bumper. To trap more air and be more aerodynamic I think a set of bumper shutters with a simple opening would help them out but they've worked fine for me as is.
Old Aug 30, 2021 | 02:01 PM
  #3620
ViciousLSD's Avatar
I feel like there's missed opportunity here to maximize the surface area that would funnel in the air. how about these
https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
Old Aug 30, 2021 | 06:31 PM
  #3621
kyoo's Avatar
thinking about swapping out my omni 4bar for stock - is stock map sensor suitable for a stock turbo car on e85, making ~360whp? or should i stick with the omni 4bar?
Old Aug 30, 2021 | 06:36 PM
  #3622
RazorLab's Avatar
Evo X / JDM Map sensor is good to 31-32psi.
Old Aug 30, 2021 | 07:10 PM
  #3623
kyoo's Avatar
sorry this is for an 8/9. or is that what people are using the evo 9's?
Old Aug 30, 2021 | 07:15 PM
  #3624
RazorLab's Avatar
Yes. Before the 10, we would use the JDM 3 bar map sensor. Now with the 10 out, it's the 10 / JDM 3 bar map sensor. Same sensor.
Old Aug 30, 2021 | 07:29 PM
  #3625
kyoo's Avatar
perfect - yea would definitely prefer the oem reliability from a mitsu map sensor.
Old Aug 30, 2021 | 07:31 PM
  #3626
RazorLab's Avatar
Just remember you will need to make changes to your rom for it to work correctly. It's easy though.
Old Aug 30, 2021 | 07:32 PM
  #3627
kyoo's Avatar
right, thinking about it in conjunction with a retune.
was about to buy from a vendor but ebay's got these suuuuper cheap if anyone else is looking: https://www.ebay.com/itm/13363942564...wAAOSwT-he~pge
not to mention all the take-offs from stores that part out cars
Old Aug 30, 2021 | 09:34 PM
  #3628
Construct's Avatar
was about to buy from a vendor but ebay's got these suuuuper cheap if anyone else is looking: https://www.ebay.com/itm/133639425647?hash=item1f1d87ce6f:g0wAAOSwT-he~pge
I don't know if I'd trust unbranded eBay parts shipped from China over the Omni 4bar.
I'd try to get an Evo X take-off if possible. That's what I have. OEM is best.
Old Aug 30, 2021 | 10:01 PM
  #3629
kyoo's Avatar
true good point - plenty of take offs on ebay too
Old Aug 30, 2021 | 10:16 PM
  #3630
deylag's Avatar
There are vendors that are on ebay selling replica sensors now. Extremely good replicas. IACV, MAP, and other sensors. Dont buy them as they are not the same quality as OEM. You can identify these replicas as they will be priced lower than normal.
